Brake line non return valves
(In Topic #143300)
Secretary
On Tin tops there is no non return valve, but there is a regulator valve mounted on the N/S rear axle that both rear brake pipes go through, restricts the braking to suit the rear axle weight.
On my 87 clipper there are no non return valves or regulators for the brake pipes.
Secretary
I think i shall have to post a pic on here of them.
Macca said
Thanks for that. The only reason i was asking was that i have a couple of brake lines lying that i must have stripped out of one of my 2 project Gti s and on them, not far from where they came out of the master cylinder there are what looked like non return valves.
AHhh!!! Now I know what you are referring to, they are not non return valves, but are just 'T' pieces to allow the pressure switch for the brake lights to be connected into the circuit :wink:
Secretary
Another question for the technical minded. Does it matter what feed from the master cylinder goes to which connection on the rear brake pressure regulator?
Secretary
Secretary
Secretary
foxy
Secretary
I might just fit them as i dont want to start having to cut them in later and get brake fluid over my newly painted bay.
Macca said
Having thought more re this, i dont think they could be non return valves as surely that would cause the pressure at the rear brakes to stay high once the pedal had been pressed, causing them to lock on. Could they be pressure reducing valves reducing the pressure to the rear?
They are not pressure reducing valves, thats what the compensator does, they are one way/non return valves, Agree you would think they would cause the rear brakes to stay on, but they obviously dont.
am lead to believe you can do away with the compensator by using restrictors , would love to find out more about that cos comensators are most of £100
Bugger just sold one for £10 LOL
Speeding is like masturbation, everyone does it ,but it's not something you should record and put on the internet!!
Secretary
Secretary
