*Update* Problem with fuel pump relay or fuse board- help!
(In Topic #110728)
It's been a while since I was last here- hope you are all well.
I've just had the fuel filler neck, fuel pump, fuel tank and thermotime switch replaced with new genuine VAG items. I was going to replace the fuel pump relay as well as it's been running very hot and had distorted the plastic around the slots for its terminals on the fuse board. However, once I switched it for the new one (also VAG) the fuel pump won't prime, and car doesn't start.
Swap it out for the old one and it works fine. However, it's running so hot I don't want to leave it there. I checked with the dealer and the relay I bought was the correct one (part number 191 906 383c). The dealer had a look at the relay I have in there and it isn't a VAG unit- it's branded Kracker (part number PA66-GF30). They suggested the fuse board itself may be at fault.
Anyone had any experience of this or have any ideas what the issue might be? I don't want to keep trying VAG relays because if my fuse board is blowing them I'm paying for them.
Thanks all.
Cheers,
Meenrod
1991 Mk1 Golf GTI Cabriolet Sportline
Meenrod
I assume its a digifant model based on your sig,m but I'm not too up on what engines the later sportlines got
It isn't a Digi it's K-Jet.
Today I've ordered a relay unit from Crazyquiff- the type he has on the site looks more similar to what I have currently, so I'll give it a bash.
Cheers,
Cheers,
Meenrod
Meenrod
191 906 383c is a digifant/KR 16v style pump relay, no way that is going to work on a k-jet 8v lump as it is designed to be triggered by an ECU, which the k-jet doesnt have. You need the older style relay which takes a rev counter input
Cheers,
Meenrod
Meenrod
Cheers,
Meenrod
Meenrod
the only thing with k-jet relays is some have a rev limiter built in, and some do not (rev limiter in rotor arm instead)
Does anyone have any idea why this relay would run so hot? New fuel pump and thermotime switch have been fitted.
Cheers,
Meenrod
Meenrod
Nope- you can hear the pump but it's pretty quiet in the background.
Cheers,
Meenrod
Meenrod
its basically a mechanical choke, from cold it might run a little richer than normal at first, but engine heat will bring it off choke eventually
Cheers,
Meenrod
Meenrod
So, unplug the WUR, go for a drive and see if the relay is hot?
Cheers,
Meenrod
Meenrod
Waddya reckon? Problem with the board?
Cheers,
Meenrod
Meenrod
if you check the relay socket one o the big chunky terminals should have permanent 12v, so worth checkin that.
maybe worth checking the lift pump is workingif not the main pump has to work harder to pull the fuel thru, though im not convinced it would work at all in that case as the reservoir would be dry…
hmm actually perhaps its the lifter pump causing the problem, maybe drag it out the tank and check the filter for rusticles?
Can I get to the lifter pump from the hatch under the rear bench seat?
The filler neck and tank have been replaced with new items as has the fuel pump so I guess the only thing left is the lifter pump. Does the lifter have its own filter and is it replacable?
Cheers,
Meenrod
Meenrod
