G60 Brakes - Girling 54 ?
(In Topic #189787)
For my planned g60 conversion, I purchased a 9" servo some time ago from a local guy who threw in a set of girling 54 calipers which he said he did not know what car they came from. My understanding is that the G60 brakes could be either lucas items or girling 54's. How can i tell the difference between girling 54's for the 256mm and the 280mm setup ? Part numbers are difficult to make out with the rust but will wire brush them if this is the only way to distinguish between them
Pippo
3532-2 CN 6
3532-2 CN 3 (possibly 8 on end)
One of the calipers has old pads which are pagid 565gf written on but unfortunately these are appRently used on both 280 and 256 solid and vented
http://www.clubgti.com/showthread.php?241335
If you've been gifted a 256mm setup you are a lucky man indeed
I purchased the epytec adapters months ago but they are stored away where I can't reach them at the moment, so it's the 280 I am after.
Just measured the carrier bolt spacing as suggested and they are at about 94mm centres . Does this confirm I have the 280 callipers ? I thought some 256 calipers had similar bolt spacings ??
Saw a corrado g60 280mm setup for sale, is this the same as mk2 golf ? ie will work with the epytec adaptors ?
edit: on the calipers the piston isnt wound right back but there is currently around 40mm of a gap and looks like the piston will only go back a further 10mm or so. So based on the link by RJ I would say these are 256mm calipers
Last edit: by Pippo
As for the rear…. when I got the car it already had a rear disk conversion and the previous owner could not get a firm pedal, part of the reason he had enough and sold it to me :-). I have just been out and took the following picture (access is poor atm as the front is jacked up and I cant get the rear wheels off just now). Seems to me that the calipers are upside down which may explain the bleeding difficulties that the previous owner had ? From what I have read they should be upright or at least upright for bleeding.
Can anyone identify these calipers from the pictures ? I presume they are late mk2/mk3 as the spring will be at the bottom when fitted other way around and corrosion rules out the mk4 items
Phil
I will probably fit the late mk3 items as you suggested in another thread I read last night to avoid seizing. My concern is the balancing. With girling 54 up front pushing the 280 disks and mk3 rear calipers (36 or 38 pistons ??) will the standard mk1 load sensor balance this correctly ? Is it better to use a load sensor from a mk2 designed for disks ? I have read that the drum version holds residual pressure which is not a good thing for disks.I have also read some people use rocco 16v compensators in the m/c instead.
Also, my car has valves inline on the 2 rear lines as posted by Macca here:
http://vwgolfmk1.org.uk/forum/index.php?page=topicview&type=misc&id=running-gear_2%2Fbrake-line-non-return
Could be non return valves. In Macca's case, he stayed with drums and kept them but can anyone confirm if they should be removed for disks ?
the stock bias valve should be fine if its in good nick, if not then you could use a mk2 one. I did simply becasue my valve was bust and replacement mk1 units at the time were either impossible to find or mega expensive! I had a new ATE MK2 one in stock so I used that instead, you just need to make up an L shaped bracket to mount it and job done
Also, thinking of doing the polo 6n rear disc conversion as detailed here:
http://forums.vwvortex.com/showthread.php?4358337-polo-ibiza-stub-axle-on-a-golf-mk1-to-mk3-guide&s=72509d4e3f4f9baa2cdfd15746e4d0f0
Doesnt seem to be very common, I like the idea of the complete stub/hub/disk/pads/caliper being from the same car. Any pitfalls ? The Polo 6n caliper seems to be the new design
yeah the polo gear all a straight fit, its on my list of things to do once i change the rear beam
if you use the polo calipers just be sure to check the nipples are free, they can corrode badly due to caliper being alloy and nipple steel. same goes for the mk4 calipers
Regarding the 6n2 polo rear callipers, there are supposedly 34 and 38mm versions but when I look for new/reconditioned callipers they are all listed as 34mm (even the 1.6 gti)
I was thinking that the smaller calliper may be a good thing on the mk1, but am I thinking about this wrong? If we are displacing the same amount of fluid in a smaller piston won't this actually create more pressure/further piston travel which could be more prone to lock up ?
