Fuel pump constantly running
(In Topic #199325)
Secretary
series 1 1.6 gti cabby
My problem is that the fuel pump is running constantly when I turn the ignition on. Should this be the case? I thought that it should prime then stop until I try and start the car.
Any ideas or info as how it is wired would be appreciated.
What relay do you have fitted, VW part number or is at an aftermarket one?
Secretary
So it will be a different relay to what is fitted to my 1988 GTi cabriolet.
Secretary
My saga continues. I pulled the relays one by one, all 4 of them, and turned the ignition on to try and find the fuel pump relay.
Guess what? None of them effected the fuel pump. It ran constantly through out.
Website Manager
Looks like El-bodgo has been there before youMacca said
Cheers mate.
Secretary
Im frightened to leave the battery connected overnight at the moment.
Secretary
Secretary
Is there any diagrams that would show me how to wire the fuel pump up through a relay independantly of the fuse box?
Website Manager
If you look on the rear of the fusebox you can use one of the H spades for permanent live, and the G/3 spade for ignition live. earth to the claw above the fusebox, and the coil signal is the red/black on C/19.
finally put the pin 87 to the 3 way spade housing near the A pillar, it has a wire from the fuel pump, another for the wur/aav and the last one goes to the fusebox pin A/8. unplug the fusebox spade and swap it for your fresh relay bypass wire, sorted.
heres a link direct to the s1 section of my fusebox faq:
http://www.clubgti.com/showthread.php?219775-Fusebox-FAQ&p=1945620&viewfull=1#post1945620
Secretary
Also thanks Ade for the diagram.
Secretary
I removed it from there and plugged it into the clear 3 way plastic connector that you described. All is good now.
Thankyou all for all the help.
