Wipers/gauges
(In Topic #193670)
The car is 1982 golf GTI,
Last edit: by BAZ-GTI
i would look under the scuttle at the wiper motor and wiring for any obvious damage, corrosion or whatever, plus the wiper spindles could probably benefit from a strip, clean and regrease. The MK2/3 wiper motor is a good upgrade if non of the above helps, be sure to chop a good length of wire off the donor as the plug differs
To clean up the wiper motor so hope it help but il put a 16a fuse in and see if it helps, I was out this morning and saw the fuse box and there was droplets of water just above it from all the condensation and this weather was thinking is there any thing that I could use to cover the fuse box so it doesn't mess it up, I will be cleaning all relays and drying it out so it's clear of any water that may have got in to the fuse box, I also found a switch at the bottom of my dash on passenger side it near the fuse box it's not connected is this a factory fit on all GTIs and what's it used for, to me looks factory but not sure il post a picture up so you guys know what I mean thanks again
switch doesnt sound factory but piccy it up
edit: nope that aint factory!
I would not install a bigger fuse if it keeps blowing as you may melt the wires or worse case the car catches fire! and that will be even more work to put right.
