Washer pump
(In Topic #189998)
I am having a problem with my washer pump. The pump itself works when powered and pulling the stalk causes ye wipers to move but no pump.
Is there another relay I should check before I get into the wires?
Many thanks.
What I found was that the MFA stalk has two wires on it (brown and white stripe and red and white stripe I believe) that have been connected onto, one of them has been connected to 12v (looks like the brown and white one on MFA is connected to a yellow and red feed on the plug at the left had side of the steering column) and the other (red and white) seems to be connected to a wire that runs straight to the pump.
I thought that they maybe trying to switch the 12v via the MFA stalk but there does not seem to be any connection between them when the MFA contacts are closed, so I am now confused.
Anyone know what the MFA wires are for and how the windscreen wash pump should fire is it a direct feed or via a relay ?
Thanks in advance.
