Twin slimline radiator fans
(In Topic #193951)
i have fitted twin 10" fans both are 80w each. What is the best way to go about wiring these? I will be using the original 90-95 single speed switch on the radiator however I am concerned about the extra power running through the original wiring/relay/fuse. Would it be better to run positive and negative direct to battery with inline fuse and thicker wires or is the standard setup man enough ? I may also decide to wire in the coolant after run pump I got with the 1.8t engine
thanks
pippo
Considering where the battery, fan and switch are located, you'd be as well as putting in new wires throughout as it'll tidy it up no end. One of the best purchases I made last year was £4 for some loom tape from eBay. Very tidy.
I also upgraded to a direnza radiator too.
Easypeasy
