Full beam and indicator issue
(In Topic #193488)
I have an issue with my right hand indicator. Every time I turn it to right it pops fuse 19, the left hand side works perfect. I also have an issue with my right hand side main beam which pops fuse 9.
I posted in the newbie section but thought i would put it in the correct one.
Any help greatly appreciated.
Cheers!
Ben
Thanks for the help
do the hazards work ok or does that short fuse also
Cheers!
have a look at fuse 4 this is the perm live for the hazard switch, this one has probably popped for the same reason the indicator wiring is shorting
Or…, where have you been working on the car recently?
Many thanks for your help too!
