clock
(In Topic #193945)
Thanks for any info
I don't believe the clock has a separate fuse, but it's worth checking in any case.
you can pop the flap on the rear of the plug too then the pins pull out the back if that makes it easier, just be careful not to pull them all out as that would make things tricky to reassemble
the brown wire is the earth for the dahs so make sure thats got good continuity to ground, but its probably not that since the rest of the dash works ok (doesnt it?)
