Moisture in boot
(In Topic #184832)
If the boot seal is good, and boot lock and light seals too then it should be water tight.
Last edit: by smudge18
You could put a rubber blanking plug in it, plus your hatch seal is too short which wont be helping, the two ends should meet. Perhaps someone will have an off-cut of seal they could give to you to fill the gap?
I guess I need to remove it and replace gasket/rubber? Or do people just silicone it?
AND WHY IS PHOTOBUCKET A LOAD OF SH**E? There should be a photo above - sorry
Do u have the rubber tubes at the top of ur boot lid that are for the wires for the heated screen? Check all down the sides of the boot lid as there are also holes down the sides which cud be letting water in,
On mine id noticed that water was getting in from underneath My boot seal and getting in underneath my headliner and dripping down the inside of the c pillar so ive siliconed round the whole boot and pushed my boot seal over the top of the silicone
Water get in everywhere mate its a b*****d lol
chipster2407 said
Sound like u need a new boot seal mate, i have a problem with water getting in my boot aswell but its getting in from somewhere else,
I think I'll get some new seals for the rear lights and the boot. Mine sounds the same as yours, where water was coming down the c pillar too. There was a lot of crud under the seal when I recently took it off and cleaned it. I think I will silicone it when I get the new seal just to make sure. Thanks
When the hatch seal was originally put in by VW they applied a bead of black sealer along the top of the seal by the hatch hinges to the bodywork and then around the corners ending a couple of inches down the sides past the corners.
If the hatch seal has been off for body repainting then maybe this sealer hasn't been reapplied. This sealer also goes hard after time.
Yomp said
Another area worth checking as it gets forgotten about:
I wondered what the black stuff was! yes it has gone hard, maybe i need to re-silicone it?
I did not know this i shall do this aswell
Don't use silicone. Go to your local body paint supplier and ask for Polyurethane windscreen sealer ( in black!)
Example: http://www.amazon.co.uk/Tiger-Seal-TIG-NB-Polyurethane/dp/B002SQY852/ref=pd_cp_auto_2
