Cabriolet rear window leak
(In Topic #196375)
I know this is a pretty common problem but my rear window in the cabby is leaking rather badly from a bottom corner (on a brand new hood…).
I've read through a bunch of threads on this topic and run round the edges with silicon inside and out and still no joy!
When people recommend sealing the outside, is that by lifting the outer edge of the rear window seal and running a bead all round there under the seal?
As I would like to know the answer too as I have a small leak…
Currently Mk1less!
Currently Mk1less!
Did they fit a new window rubber surround?
Don't think it was a new seal though, although it looks in decent shape! Should I just try to find a new rear seal? Or get it out and have a go at resealing it?
Yeah. Take a look here (scroll down to bottom of page)
http://vwgolfmk1.org.uk/index.php?page=cedi&type=misc&id=1%2F42%2F31%2F33%2F34%2F35%2F36%2F37
Looks like this, I found it from a local motor factors
http://www.amazon.co.uk/3M-Windscreen-Sealer-Cartridge-08509/dp/B0002KKVDY
Then it's just onto all the other interior leaks, and that bloody door-to-hood seal…
You can get it in a tube format like silicone.
Even more info on the stuff if you have not look at my other link and found out about the stuff.
http://catalogue.3m.co.uk/en_gb/gb-aad/Glass_Bonding/Rubber_Gasket/Windscreen_Sealer/Windscreen_Sealer~08509
