Mk1 caddy 1.4 16v engine conversion
(In Topic #199679)
Im reading a lot about the engine swap but I'm reading a lot of conflicting threads so just want a clear answer
i already have the 1.3 petrol engine mount, but looking into 5 speed gearboxes and mounts what is the best option? The original gearbox in the polo has a large bulky gear change mechanism that looks like it will foul the steering rack and also runs cable shifter system the diesel box is 4 speed and doesn't fit the block size, so what is best box to go for?
Thanks in advance, Martin
the polo shifter mech i believe all unbolts leaving you with the same selector shaft poking out as you will find on a normal mk1 1.0-1.3 box, so then you need the smallblock mk1 gearstick, rod and ends to fit onto it
then its a case of bolt on a mappable ignition ecu, or find a vacuum advance dizzy that fits the polo head.
If you want more power then the 1.4 it's the best way forward, sell the 1.4 polo engine?
If insurance/cost and road tax is the problem then fitting a 1.4 is possible.
im keeping the 1.4, it's the plan I've had in my head and I'm sticking with it, every man and his dog has a 2l 16v and want something a little less seen and once I've played with the engine, port and polished the head, new cams, bike carbs, balanced up and lightened it'll be a strong engine that will have plenty of power for a light caddy.
you might have to change the flywheel for a 190mm one off one of the above too, not sure what the flywheel you have on there now will be.
the Polo 8P box is a popular one
