Accelerator cable sticking
In a bit of a sticky situation - pardon pun! Lol
I'm venturing in to the world of unknown really - no accessible funds for a garage at mo and my local garage guy cant do it til friday - when his boss is out! But need it doing today really…so am hoping I can do it myself - is this recommended? Lol
so was wondering if any of you lovely lot knows how I check this? And if I can tweak/adjust myself also or how do i know the difference between the cables broke to it just needs a tweak? Where do i look? Is this a step by step guide anywhere? Also Am I messing up the car if I drive it like this etc?
Any help would be massively appreciated x
chelle
long live bew:)
is it a gti chelle? or a carb model
Weber carb jelly x
chelle
long live bew:)
leave it with me for 10min and i'll sort alittle something for you :)
Oooh thank you so much!! 😊
chelle
long live bew:)
right then :)
on the right had side of the carb is the cable
you can kinda side the cable coming in the front right hand side then it goes round a rocker thingy
when to twist it the accelerate is should spring back instantly, notice the big spring :)
then follow the cable bad and then is disappear into the bulk head, through a rubber grommet. just make sure this is free and the cable isn't trapped or has big kinks in it
then  you need to look under the dash at the top of the accelerator pedal. the cable should connect through a rubber grommet at the top of the pedal
it's hard to see but in the right position you can see it
got have  look a report back
Aw your a star!!! Ok I'm on it x
chelle
long live bew:)
Ok, once I got my bonnet open (had to find pliers as don't have a handle!! Bloody tough!)
I can see everything you say springs fine and cable etc, not trapped or anything.
Looked under throttle - no niggles - all fine - the pedal goes down and comes back but is sluggish - almost needs my foot to pull it back up at last cm or so if makes sense?
I can't see the what happening at front whilst I test pedal - wish I inspector gadget arms -
Does that help?
chelle
long live bew:)
Water pump def needs doin tho - fack
chelle
long live bew:)
the leaver on the side of the carb you can twist that while you under the bonnet
twist it and see what happens
if the leaver spring back but the cable doesn't then there a problem with the cable
go try that :)
Yep springs back with cable
chelle
long live bew:)
Next? Lol
chelle
long live bew:)
ok that must be alright then
is it a manual choke? just have a look at the choke cable which runs next to the accelerator cable
Yep manual choke - that's working fine
chelle
long live bew:)
well chelle
without being there i aint sure :(
sorry
Aw ok - thanks anyway! You ve taught me something anyway! Really appreciate you trying! X
chelle
long live bew:)
If the return spring and throttle lever on the carb are OK it could be (a) kink/tight curve in cable routing, (b) the inner cable is sticking in outer sheath, (c) the pedal/pedal arm itself is catching on something, (d) the bush in the pedal arm that the cable hook goes through might be causing a problem as these like to disintegrate at inconvenient moments!
Um........ Quite a few things then... Hmm
chelle
long live bew:)
Should be fairly straight forward but if you get stuck and need quick fix drop it round ours after work or can pop over. Might need parts though so good no what is wrong/broken first.
