New kid!
(In Topic #184748)
I'll be soon picking up a Black 1990 Golf MK1 Clipper Auto.
Needs a lot of TLC and is currently sporting some kind of crazy A-Team look! (Will post pics soon)
Anyway. hope to restore it over the next few months and I may have quite a few questions for you.
There's a meet coming up in your region too so be sure to check that out
Is this your first MK1?
Well, where do I start…Hairyarse said
That looks tidy. Apart from giving the hood a scrub, what does it need?
It's not been started for 2 years! No MOT or tax etc. The bodywork looks really good, a few early signs of rust but really good for the age actually. Had a full respray 3 years ago and a now hood but can't wait to get stuck into it now. I'll drain the old fuel etc and replace with fresh stuff but what else should I change before attempting to start her up? Obviously, the red bits need to go too!
First MK1 this, had a few MK3's and MK4's and various other cars from VAG range. My daily driver is a Skoda Fabia VRS MK1.
I would change oil and filter, coolant too and brake fluid but the latter two could wait for a while if just starting for now and they look ok.
Check cam belt and alternator belt, check plugs, dizzy cap etc all looks good. Whilst plugs are out perhaps put a couple of drops of oil down each bore and turn engine over by hand to ensure that it's free. Then before starting up for the first time, remove coil HT lead to get some oil pressure up, check oil light goes out then connect back-up ready for firing.
Oh and new battery - or at least charge the old one.
Generally these old gals start-up well from being sat but it's worth taking every precaution not to cause any damage
If I've missed anything I'm sure someone will dive in
Apart from the red (which can easily be changed) the car doesn't look that bad overall.
I think Hairyarse Is about on the money with his suggestions!
One thing though, watch the brakes!
When it runs for the first time the temptation is to take it for a short blast down the road but that might be when the brakes give you a big reality check!
What oil do you guys use? 0W-40 Fully Synth? I think the engine has done around 90k.
Hairyarse said
I'd go semi-synth personally
For semi-synth
I'm using Castrol 15-40 but I think a number of people here use 10-40!
Looks good mate, welcome along, look forward to meeting you at some shows and meets, and make sure you check out the AGM, a weekend not to be missed
1.8T CABBY
1.8T CABBY
cbdubs said
Yeah I use a decent 10-40 semi - never had any probs but I do change it every 6 months and use a genuine filter.
Yeah, i'll stick to that then. Cheers
richyhill said
i aint getting on no plane fool!
For sure, what shows do you reccomend? I'll probably be at the Stanford Hall one in a few weeks as thats just up the road. If i can get the clipper mobile by then of course!
Other shows I would recommend are:
AGM - MK1 Golf Annual Gathering - not to be missed
Bristol Volksfest - check out my thread in National Section
Malvern Classic Car show - end of the year
1.8T CABBY
1.8T CABBY
