K-Jetronic: Troubleshooting Symptoms
Thanks to Douglove for this …..
K-Jetronic is a mechanical system:  the fuel is continuously metered in proportion to the quantity of air drawn in by the engine.  The K-Jetronic system was installed as Original Equipment in series production vehicles in the years 1973 through 1995.  Since then, the K-Jetronic system has been only of significance for repairs and maintenance.
Symptoms:
Engine does not start/starts hard when cold
Engine does not start/starts hard when warm
Irregular idle during warm-up
Irregular idle with warm engine
Engine will not accelerate, backfires
Engine backfires under load
Poor Performance
Engine runs on
Fuel consumption too high
Driving performance unsatisfactory
CO concentration at idle too high
CO concentration at idle too low
Idle speed cannot be adjusted (too high)
Engine starts but immediately dies
Symptom: Engine does not start/starts hard when cold
Cause
 Remedy
Sensor plate and/or plunger not moving freely Check for free movement
Auxiliary air valve does not open Check valve for correct function
Electric fuel pump not operating Check pump fuse, pump relay and pump
Cold start system defective Check cold start system
Therm-time switch defective Test thermo-time switch
"Cold" control pressure outside tolerance Test pressure
Injector leaking, opening pressure low Check injectors on tester
Injected fuel quantities unequal Check for equal fuel quantities
Basic idle setting incorrect Check and adjust CO level
top
Symptom:  Engine does not start/starts hard when warm
Cause
 Remedy
Leaks in air intake system (false air) Check air system for leaks
Air flow sensor plate stop incorrectly set Check and reset
"Warm" control pressure too high Test pressure
Fuel system leakage Inspect fuel system for leaks
top
Symptom:  Irregular idle during warm-up
Cause
 Remedy
Cold start valve leaking Check cold start valve
Lambda control system not functioning correctly Check Lambda control system
top
Symptom:  Irregular idle with warm engine
Cause Remedy
"Warm" control pressure too low Test pressure
top
Symptom:  Engine will not accelerate, backfires
Cause Remedy
top
Symptom:  Engine backfires under load
Cause Remedy
Primary system pressure out of tolerance Test pressure and adjust with shim
top
Symptom:  Poor Performance
Cause Remedy
Throttle butterfly does not open completely Check butterfly and stops in throttle venturi
top
Symptom:  Engine runs on
Cause Remedy
top
Symptom:  Fuel consumption too high
Cause Remedy
top
Symptom:  Driving performance unsatisfactory
Cause Remedy
Excessive fuel delivery to control circuit Check fuel delivery
top
Symptom:  CO concentration at idle too high
Cause Remedy
top
Symptom:  CO concentration at idle too low
Cause Remedy
top
Symptom:  Idle speed cannot be adjusted (too high)
Cause Remedy
Auxiliary air valve does not close Check valve for correction function
top
Symptom:  Engine starts but immediately dies
Cause Remedy
top
