QUAD GRILL INNER SPOT LIGHTS
(In Topic #95056)
they have the mk2 inner spots does anyone know if these are the same dimensions as the mk1s i have in my grill???
thanks
what i dont know about engine work…
is worth knowing about
are they the clipper style grill lamps
Tian :wink:
bens_cab said
pm dub76 ive gave him a set i had knocking around he may still have them mk2 ones are different i think
Some of the aftermarket lamps on the evil bay claim to fit both Mk1 and Mk2 mate.
Tian :dontknow:
cheers for your reply i will ring gsf see if they could possible measure up the lamps for me.
i will also look on evilbay now for some. i want brand new standard ones i dont want clear or cross haired etc
you should come to our next meet, it's down in buxton on 24th feb.
there's quite a few of us leaving brighouse and then meeting up with other mk1's from other areas, such as wrexham and chester, there's a thread on it in the regional meets section, the one with 11 pages
1983 Polo CL - daily
1984 Golf G60 Syncro - sold
1989 Rallye Golf - sold
1992 Corrado G60 - crushed
1991 309 Style - crushed
john im in pontefract mate. me and 'pete and mel' are both from here i hav a 92 rivage he has a 93 clipper. we were on about tryin to get involved in something so will have a look. would love to see a load of mk1s in a convoy let alone be involved in one.
buxton derbyshire?
should be a really good drive down to buxton, some mint roads
summer meets would be good for warmth cud bring lass without her whinging shes cold ha.
back to topic…what are these lights called coz i cant see um up on list at euro.
http://cgi.ebay.co.uk/VW-Golf-MK1-Inner-Headlights-Crystal-lamps_W0QQitemZ180115159272QQihZ008QQcategoryZ23009QQrdZ1QQssPageNameZWD1VQQtrksidZp1638.m118.l1247QQcmdZViewItem
Myn where very cloudy but results below.
take off front grill - two screws on top and a further two under the corner gromets.
Unclip from the inside and gently pull away, disconnect inner lights at this point.
Once you have the unit off gently straighten the three tabs holding the bulb holder to the reflector.
pictures at bottom to help. Be carefull not to break earth tab, which i nearly did on one.
Once you have got this away you can then clean the inside of the unit gently.
assemble is the reverse as they say.
pic showing tabs strightened
pic showing holder removed so you can get better access to clean insides.
1988 1.8 carb Golf Clipper
what did u use to clean them with as your have come up like new.
cant believe how expensive they are to buy
milky white before so does work.
really impressed with how them lights hav come up. my new headlights dont look that good. my inners spots look shocking. before and after pic coming ur way i think
not missing anything, thats spot on.
Once you remove the grill and disconnect the bulbs you then have access to the tabs on the inner spots. Straighten these and then you can pull off the bulb fitting, leaves you with a hole plenty big enough. Got another pic will post once photobucket lets me in.
will become more obvious when you have started.
cant wait to hav a go at this and save sum cash. cant afford the 60quid to replace them thru ebay and gsf hav discontinued them. booo
i'm gunna have to do that as money needs to to else where before i start bying new lights.
hope the weather's good for the weekend as meguires will be used in vast quantities.
im guna bang um in dishwasher me. perfick
wat polish u on wi now then pete urs looked sparkling wen i saw it. i use mer. its decent to be honest.
and ive bought one of them sonic scrubbers for wheels as mine are a mare to get into nooks and crannys. its mint.
