Fuse number 18 pain in the butt
(In Topic #144815)
I believe it's for the horn and coolent temperature ( probably wrong like )
I tried a larger 30 fuse instead of the standard 15 in case it was bodged to power other things but it still popped
Oh its a 1986 golf gti 1.8 8v cabriolet
start with the relay pop it out and check for corrosion in the socket. look at the wires out the back too follow the black or black/yellow wire back to fusebox. if all looks good check the horn wires next, unplug them then follow the wiring back as far as you can. if that all looks good leave relay and horns unplugged, then swap the fuse over. switch ign on, if fuse blows again you have wiring or fusebox issue, if not then its either the horns or the coolant control relay. plug them in 1 at a time and try again, see which one blows the fuse.
check the wiring to the horn relay as well, there should be a jumper wire from L 1 to A25. see the fusebox sticky
I'll do my best to follow that eek! Electrics are not my strong point
If its my fuse box will a carb model one work?
Thank you
The fog light does not receive any power with 2nd click and fuse is ok and all connectors are clean and tidy. Could it be the headlight switch? I know it only comes on when the headlights are switched on.
disconnect the brake pedal switch wiring, see if reverse lights go out then. there should be a 2 pin plug near the fusebox with a red/yellow and red/black wire, this is where the brake light switch loom joins the fusebox, the plug hangs off the yellow plug for the lighting loom fyi.
for the fogs, follow the wires from the fog light switch back to where they come from. there should be a grey/yellow wire back to the fusebox this is the power input, it should be live when the lights are on. not sure if its on with sides or only dip/main on a CE1 fusebox, so check both. then trace the grey/white that should run direct to the fuse holder, then the other grey/white from fuse holder goes to the fusebox B/2. then the rear wire runs from E/10. with the fogs switched on check for power at all the above points to see how far power actually gets
