Oil pressure buzzer and light keeps going off
(In Topic #190109)
As a starting point the garage has changed both low and high pressure switches.
However this weekend the buzzer was going mental on the way to and from edition 38.
It just stayed on constantly for five minutes and then randomly went on and off and various speeds and I couldn't find a pattern to are it come on or off.
Please help as I don't know what to do, it drives spot on, but did randomly stall a couple of times and struggled to start in traffic and was then fine again so that might just be a random issue as it was a very hot day on Sunday…
Any thoughts or suggestions please, do I change oil pump, do an oil and filter change or something else…
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
Currently Mk1less!
So, if you turn on the ignition you shouldn't get a buzzer, if you start the engine and leave it at idle you shouldn't get a buzzer,
if you then raise the engine speed until you pass 2000rpm the buzzer would sound (assuming the oil pressure was low) and then stay on when returned to idle. When you switch the ignition off and then back on the sequence should be the same ie buzzer off until over 2000rpm.
If the buzzer is being activated it could be;
1. Low oil pressure caused by thin oil, worn oil pump or blocked oil pick up
2. Oil pressure switch faulty (you've changed yours so you could rule that out)
3. Oil pressure switch wiring faulty (this is what caused my problems)
4. L-shaped circuit board in the dash faulty
If your buzzer is coming on randomly (not over 2000rpm) it would point to the circuit board being dodgy.
If you are able to check the oil pressure that would be a good start; at least you would know that you're not going to do any damage by ignoring the buzzer.
Have you ever had the dash apart? There would be an L-shaped circuit board on the back of the clocks; it has a small buzzer on it (looks like a small relay).
Like this:
http://i288.photobucket.com/albums/ll199/fatrbt/OilWarningPCBoard.jpg
The Red Rocket! My Mk1 Tdi Build.....
My VAG family:
1982 Mk1, PD130 Tdi, 6 speed, ongoing project, to be my daily driver (one day)!
1983 Mk1, 1.8 Gti, stripped out, ongoing project, track car only.
1990 Mk1 Cabrio, 1.8 8v Turbo, G60 ECU, long term project (17 years so far)!
2008 T5 LWB, 1.9 Tdi, to be converted to camper when I've finished using it as a van!
1999 Audi A4 Avant Quattro, 2.5 Tdi, currently off the road, more work required.
2010 Tiguan R-Line, daily driver.
My VAG family:
It was buzzing at standstill every so often ie under 2k rpm.
I will get my trusty mechanic Mits530 to take a look at the wiring.
If that's all fine do I look at replacing the oil pump first or the circuit board behind instrument cluster and I'm guessing I'll have to buy a used part..
Currently Mk1less!
Currently Mk1less!
