Timing belt change interval
(In Topic #202596)
When should you change?
There's various opinions on when they should be changed but as the cars are far from new, I'd change them at 40-50k.
I'd also pull the cover off every 10K and have a good look at it.
If you do change the cam belt, replace the water pump at the same time!
Regards Volkswarren
volkswarren said
its not on a mk1
Strange because jazman is asking about a Mk1 Golf GTI, or at least that's what I thought I'd read above.
If your water pump goes you have to take the belt off etc… to gain access to it, so while you're changing the belt it's advised to do the two together.
The pump won't cost an arm and a leg, that and you have piece of mind about when that was last changed!
If it goes on a mk1 u have to remove the fan belt, not the cam belt.
Waste of time changing every time you do a belt on a mk1 GTI.
Regards Volkswarren
Regards Volkswarren
I understand what you mean but I've always understood that it's just best practice.
So how often do you recommend changing the belt and how often the water pump out of interest?
I can check my auto data book tomorrow but it's every 4 years I think. For a belt and tensioner, I'd doubt many mk1s need worry about the mileage side of the change.
Regards Volkswarren
