Timing belt change questions
(In Topic #198108)
Read up all the relevant threads on here regarding changing the timing belt
I have started to loosen the bolts to remove the following
- crank pulley - 4 allens
- waterpump pulley - 3 allens - one is seriously threaded
- cam pulley - 1 bolt
I have a few questions
1. Can I change the timing belt without taking the water pump pulley off
2. Will the lower timing belt cover come off without the waterpump pulley coming off?
3. how do I tension the tensioner?
I haven't taken anything off yet just wanted to make sure I could loosen the bolts ready to take off first which im glad I did as the water pump bolt will need chopping off
thanks for the help in advance
Alps
Last edit: by Alps
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
1 & 2. No you cant change the timing belt without taking off the Waterpump Pulley as the cover is tight behind it. DOH!
3. worked it out
Threaded waterpump bolt was seized on hard, torq bit hammered just sheared the bolt more so ended up drilling the head off, funny as it was spinning nicely after that and managed to unscrew the remainder easily.
will update with pics once completed the next phase
Check and double check all the timing marks once the belts is back on as it's really easy to be a tooth out, the car will start and run but will be down on power and may pink under load. If it sounds like a super charger is fitted once the belt had been tensioned it means it to tight.
I use a little spot of copper grease on the threads of the bolts for the water pump and bottom pulley so they are easier to get out next time.
Mark - timing may have been out already as it pinked under load- it could have also been to the oil pump on its way out, so I have bought a new one of those too. new bolts arrived so will grease them up.
rubjonny - thanks , that's a good tip
have been away for a few days so will carry on today as the 2nd seal for the intermediate shaft has now arrived.
thanks guys
Changed all the seals put everything back together no problem
I am however struggling to keep the crank from moving when doing up the tensioner, I tried about x10 times and it still looks out buy a cog compared to the cam.
any tips here? thanks
the smallest unit of adjustment is 1 tooth so once you do this you can see if the cam needs moving a tooth either way, or if its close enough
Managed to get it all back together, seemed half a tooth out but after looking at some threads it seems normal!
threw me a bit when I had two of the leads the wrong way round but that's sorted now.
thanks for all the help
after changing the timing belt etc it seemed to be as it was before , still a little lumpy and hesitating on low and high revs.
last few months its been sitting in the garage so i thought id give a few things a go to get it running properly again, so i changed the following;
- tank fuel pump
- outside main fuel pump
- swapped coil
- swapped ignition module
just need to know what i can check on the metering head as that might be the culprit!
