Clipper Cab, Problems
(In Topic #207419)
![Avatar](https://vwgolfmk1.org.uk/uploads/ocf_avatars/28948573836_68c22ebcd5_m%20%20%20avatar.jpg)
![Tankerman24 in the usergroup ‘Regular’ Tankerman24 in the usergroup ‘Regular’](https://vwgolfmk1.org.uk/themes/default/images_custom/m4O9bNA.png)
Engine has cut out and refuses to start
Its appears to be electrical but where to start, Icant find any broken or loose wires anywhere, the guy from the recovery garage said it could be my HT leads but I think it isn't going to be that easy although I will replace those.
So the car is now looking sad sat in my garage. I just thought Id ask if anyone had any pointers that I can look at when I get time next weekend.
BTW its a 1.8 with a webber carb.
Hope you've all had a good weekend. Thanks Steve
If you are buying some new HT leads it's worth buying a new dissy cap and rotor arm as well. I replace mine every 2 years but my car is a daily drive and I need it to get to work.
How old are the spark plugs?
When the car stopped did the dash lights come on or did everything go dead?
![Daytona in the usergroup ‘Paid Member’ Daytona in the usergroup ‘Paid Member’](https://vwgolfmk1.org.uk/themes/default/images_custom/7vW13sh.png)
![Daytona in the usergroup ‘Old timer’ Daytona in the usergroup ‘Old timer’](https://vwgolfmk1.org.uk/themes/default/images_custom/XW2jYK6.png)
![O_o](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/blink.gif)
![:'(](https://vwgolfmk1.org.uk/themes/default/images/ocf_emoticons/cry.png)
![golfcabrio in the usergroup ‘Moderators’ golfcabrio in the usergroup ‘Moderators’](https://vwgolfmk1.org.uk/themes/default/images_custom/OeIGBY0.png)
![golfcabrio in the usergroup ‘Local hero’ golfcabrio in the usergroup ‘Local hero’](https://vwgolfmk1.org.uk/themes/default/images_custom/2T6Iw1M8.png)
![001.JPG 001.JPG](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_1024/v1508058319/uploads/attachments/59e324cda030d.jpg)
Thanks.
Marcus.
Apologies for robbing the original post Tankerman!
if that helps then the ignition switch cant supply enough voltage or there is a problem with the power feed from the switch to the fusebox/coil. alarm/immobiliser is a top suspect if you have one
will do what you suggest as it removes a lot of the guesswork. Will hook it up so that if it fails again will then connect this into the system.
On the fuel side I blew gently into line from tank and it was pretty much blocked- then it released suddenly-, and, I could then hear my air bubbling in the tank. New filter in line and had a drive out and it went without missing a beat. (On reflection, it was after filling up that the problem first occurred).I will still do the magnet in the tank trick.
Also should soon be getting an unworn original Bosch 205G distributor which should help things too.
Thanks again.
Marcus.
This week a local auto electrician came and had a look, we got it started then it cut out as usual. he traced the fault back to the hall effect sensor in the distributor, probably due to heat over the years.
So I started to look for a new distributor but everywhere I phoned I was told it is now an obsolete Item.
Ive now contacted a firm who I used to build me an electronic ignition dizzy for my V8 Westfield, Ive used them a couple of times now and the service is brilliant, they could have replaced the Hall effect sensor for £45 but they are going to recondition my dizzy for £145 this is a full rebuild with new parts and blast the metal parts so itll look like a brand new unit. the company are called H&H ignition solutions ( nothing to do with me but definitely highly recommended) I will let you all know how it goes. I removed the Dizzy today, will post to them tomorrow, they recon on around a weeks turnaround.
While I was waiting for the parts I removed the fan shroud, sanded and resprayed it and gave it a new replacement sticker. Im now hoping the weather improves so I can have a good run out.
![Dizzy.jpg Dizzy.jpg](https://res.cloudinary.com/mk1-golf-owners-club/image/upload/c_limit,w_768,f_auto,q_auto/v1479668832/uploads/attachments/5831f46034c68.jpg)
