Coilovers? Are the cheapies worth it?
are these the coilovers every one is talking about?
looking to have a go at some cheapies.
C.
or yes if that makes more sense
Handles like a go cart, next to no body roll (even without anti roll bars) and very easy to adjust.
Greased mine up with that spray grease as Im not fussed what they look like. Just got to see how long they last.
Oh, and they go really, really low. The first night I put them on, I had them at the lowest they can go. I was hitting man hole covers :twisted:
WOund them up a tad the next day
a mate of mine had a campaign and he
payed twice what i payed and his bounced
allover the place, not sure what make they were
mine a very comfortable for how low she
is as for corrision i only bought coilovers
to get my car low so don't need to adjust em.
im really thinkin of gettin some
who else has got them??
just need convincing really?
sam
well worth the money
mite be worth getting a pair of wheel spacers and longer wheel nuts for the fronts cos mine needed 10mm spacers to clear the springs but i have got 8 inch wide rims on the front and 9's on the back
Ive actually got 2 pairs if you intrested in a cheaper one, no c spanner though.
coilovers
Got a set of cheap coilovers on german ebay.
Quality is good ,but at the front ,when wound down quite a lot, I figure they have no travel left, the only give is in the top mounts…!
Measurements seem to back this up….
I have noticed other mk 1 s that are definitely sitting lower..
Do some coilovers have a shorter shock body ?
( Mine measure approx 320mm overall )
dave_dub86 said
took the helper springs off the back end and the rides a thousand times better! nice and stiff and the wheels have stopped touchin the arches!
tht doesn't sound like a particularly good idea to me i thought the helper spring was there so that if the shocker has to extend the helper spring also extends and stops the spring from just flapping about??
novocaine said
mot failure.
thought it sounded a bit dodgy…..
no mate its there to smoothen out the ride. i know what you mean about the shock extending, but i checked this as i wound the single spring up and it was still tight when the shock was fully extended. if you wound it all the way down so the car was as low as possible i think youre right and the spring wouldnt reach both ends of the shock when extended but its fine where i have it.
