76 Golf Resto
76 Golf Resto
Anyway, looking fantastic love the colour!
1992 Pearl Green Clipper Cab - 16v (9a block, KR head, GSXR600 Carbs)
mcscrew said
Steve - I'm too attached to my silver stars (and too tight) to part with ?15 and become a member ops:
Rich
I'll tell you about the benefits next week… Well worth it, especially when you start putting back together..
Rich
Chairman
mcscrew said
Cool… Am intrigued. All will be revealed I'm sure!
Rich
I could get rid of those silver stars
Car looks good mate, get it finish though
1986 Cabriolet (long resto!)
Follow us on:
Follow us on:
The barn looks huge is it easy to obtain storage in something like that as in… is it yours or did you ak a farming friend or something?
looking forward to seeing this progress mate :wink:
I'm half way through welding up some rollover frames for the shell, and once they're on I'll restart the bodywork again.
I've been tinkering with the engine, but haven't got much further than a complete stripdown. I'll document the mods and rebuild of that as it'll be a bit of a 'special'.
I'll stick some pics up this weekend 8)
Rich
There's tons of barns about near me, but I find you have to know the people before they'll rent you them, and even then they want a lot of money (except for my landlady 8))
Rich
Where abouts is these barns? As I have a few mate in the Reading area who was looking for a cheap lockup/barn.
Rich
I'm going to clean them all up, balance the weights of the pistons and rods, skim some material off the top of the block to increase the compression ratio, and lighten and balance the bottom end.
In the end I did jot down the orientation of the pistons and con rods - I made a note of the con rod caps and have marked the pistons and rods accordingly.
As far as I can tell, this is how the bearing shells should line up (was pretty difficult to focus the camera properly)
I've also made some rollover frames, based on regcheeseman's design (link here) although the one in the pic isn't quite finished yet…
I ordered all the parts cut to size and welded them together. I'll stick up a cutting list once I've ironed out a couple of mistakes.
I bought a gearbox and a couple of other bits today, and as it's going to be raining this weekend there'll hopefully be a bit more to show next week :?
Rich
Cleaned the block
Then tackled the pistons, which were pretty dirty
They came up pretty well (I used a wire brush on a drill and some WD40)
And while cleaning them I discovered an arrow on each one, which I presume when it's rebuilt will point towards cylinder no. 1.
So, good to know that if you forget to note the alignment before you dismantle the engine, you can still recover the situation.
Rich
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
Will you be coming on wed to the Berkshire meet. Would like to meet up
Max
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
Thanks for the encouragement too - I'm looking forward to seeing how it turns out myself!
Jellybelly - here's a cutting list, all out of 40mm box section: -
4x 300mm (bolts to bumper mounts)
2x 1700mm (horizontal bar)
2x 1200mm (vertical bar)
2x 550mm (legs)
2x 510mm (legs to fit under curved section)
2x 600mm, with 45? each end (brace between horizontal and vertical bars)
6x 172mm, with 11.25? each end
4x 172mm, with 11.25? one end
The steel cost me ?165 + VAT.
HTH
Rich
Diesel Possessed
A97JCE
Feeby
A97JCE
Feeby
The frames worked really well, with the shell going over pretty easily, and it seems to be sat very comfortably so far. Fingers crossed my welds hold up 8O
Rich
your work is looking goodmcscrew said
Have got some more done, but my ftp site is down. Will put some pics up later hopefully…
Rich
