Engine restoration - need some help
The project is currently on hold so I can get xmas and new year out of the way. I managed to get a few photos of the 1976 VW workshop manual as wel so they should help me a little.
Baz
1. I need a pic of the dipstick tube on a 1.6 so I can check what I'm missing. I have bought a small orange tube and it might not be the correct one as I'm not convinced it fits very well.
2. I have most of the water system back together and next is the fuel and vacuum pipes so if anyone has a diagram of either I'd be very greatful. The Carb is a Solex 34 Pict-5.
I'd like to have this little beastie up and running before easter. I've just managed to get another MK1 for parts as well but it's a bit worse for wear and was a 1300. I'll just be taking the non-engine parts I need and selling off the rest probably in pieces but we'll wait and see.
Baz
~Tom Parker
Currently Restoring a Cabrolet GL
5% complete?
5% complete?
Life Member
Bazmcc said
Well here's a little update. I've made some sort of progress but I need more help.
Connections to the carb depend on the year. There should be a vacuum pipe from the distributor vacuum unit to the choke vacuum diaphragm(held by 4 screws to the carb body).
There should be a 12V feed (black wire) from the coil to the carb cut off solenoid and the choke bi-metallic strip element (round unit held by 3 screws on a retaining ring). The carb body also has an earth tag on it. Later carbs have the choke also running on water temp so have an inlet/outlet on them.
I just need some help no finishing the water system. As you can see from the pic below there's a few pipes still to connect. (ignore the wiring, it's a total mystery).
So, currently I have still to connect:
2 pipes coming from the airbox in the firewall (one with the cable controlled valve in it?)
1 open end on the intake manifold
and
on the metal pipework which lays around the corner of the block there's a piece of 'U' shaped pipe joining the top upper and lower parts of this plumbing together. I think this is wrong.
If anyone can confirm where these pipes go it'd be great.
