Fuel tank removal..... FINISHED!!!!
penny said
wow thats ?45 cheaper than anywhere i looked, thanks, well its just the manifold that really needs to be replaced sooner or later, the rest of the exhaust system is fine really, no decisions are ever easy when mk1's are concerned are they?!
Its okay - I only just found that website, after a tip-off from CGTI forum! Shall I send you my Paypal account and you can send the ?45 to me??? Nah, then I'd have to send it on to my tipster!
I'm now mk1less, ahhhhhhh!
Gone but not forgotten;
'83 Schwarze black GTi
'83 Lhasa green GTi
'80 Indiana Red Met. GLS
'83 Lhasa green GTi
Cheers,
Dave
'83 Lhasa green GTi
'83 Lhasa green GTi
It's surprisingly difficult to get all the bits out - I used loads of petrol and shook the tank until no more came out, but it took a while and the tank's really awkward to hold in a position where fuel drains out quickly.
People have had varying degrees of success using a large magnet underneath the inspection cover, followed by a small magnet on a stick. This may be worth a go first, although I found it didn't work very well for me - the small magnet kept sticking to the tank and not to the bits
How much stuff is in there?
Rich
tankk removal
Sp1der
tank removal
Sp1der
Dave
'83 Lhasa green GTi
'83 Lhasa green GTi
or
try the cast of 'Honey I shrunk the Kids' - not to be confused with the sequel 'Honey i blew up the kids' - they wouldn't stand a chance of gettin inside.
its nearly home time
'83 Lhasa green GTi
'83 Lhasa green GTi
something I'm thinking of doing next year is replacing the back axle and tank
'83 Lhasa green GTi
'83 Lhasa green GTi
and i did make things difficult by not dropping the axle completely though, good luck anyway!!!!
Agree there . Can't see the point of wrestling with the exhuast when you can just undo the brake lines/hoses and completely remove the rear axle. Handbrake cables should be easy to disconnect and if the flexihoses and lines are that difficult to undo they probably need replacing anyway as they are either corroded or have been cross theaded.
1983 1100 C
1983 1100 C
cheers for all the advice on the way, btw got away with re-fitting the old centre section after the angle grinder had a go at it, woohoo!!
Dave
'83 Lhasa green GTi
'83 Lhasa green GTi
Luckily, I was able to undo the flexi hose to rigid hose connections without destroying the connection, so it was a simple case of refitting after.
It took me around 6 hours too, I did some yesterday and nearly finished today. I accidentally ran the master cylinder out of brake fluid, so now I have to bleed the entire system! And the battery is going flat too (and its an auto so there's no chance of bump starting or anything). I guess with a carb engine (and mechanical fuel pump), you just keep turning the motor over until it picks up fuel?
Yes, my mk2 1.8 carb ran out of petrol the other week. Took a good 20 secs of cranking to get the fuel through, pumping the throttle pedal while turning it over seemed to help.
1983 1100 C
1983 1100 C
