leaking water pump
leaking water pump
I know this tip is a little late……. but for future jobs where you can just tell its going to be a mission to un-do bolts …..
Either dab on some engine oil and leave to soak…….
or spray some plugas on…… it's good stuff.
If you use a impact driver you can shock bolts loose that are seized. :starwars:
Like I said not much use now but a good tip for next time. ops:
If you've not seen Plusgas before this is the stuff………….
"Treat each problem as an adventure rather than a pain"
Helps the troubles faid I found, I know from experience what seams llike an afternoons work decends into a week off the road
Good luck
Rob
Audi A4 1.9TDI - Gone
I am about to attempt mine and I am nervous!!
<a href="signature2.jpg picture by jools182 - Photobucket"><img src="http://i88.photobucket.com/albums/k182/jools182/signature2.jpg" border="0" alt="Photobucket"></a>
jools182 said
Where can you get new bolts for the water pump from?
VW Dealer.
if so i have a near new (3 weeks old one) from gsf that was fitted to a 1.6 gti 8v but ive now replaced with a brand neew vag one and replaced my hoses and metal water pipes.
if you need it drop me a pm or give me a ring and i can try and send it out tomoorrow morn
Yousaf
07816002453
can i ask why you changed it for a VAG one? Are the aftermarket ones no good?
