Misfiring & pulling injectors
(In Topic #73179)
Thought I would give Prowler's injector test a go, but cannot get any of the injectors out? Did prep with a bit of WD40, but they seem incredibly tight. Had tried with long nose pliers pivoted on rocker cover, but the keep slipping - tried pulling out by hand, no joy :dontknow: .
1983 1100 C
1983 1100 C
If your running the car have you tried a good injector / fuel cleaner ? I had sticking injectors and rough running , gave the car a good dose of Redex cleaner , a few 100 miles later and no more problems . I always run my Mk1 with fuel cleaner in every forth tank of juice
Cheers …..
Guest user
Injectors
Geoff
I did manage to get molegrips nicely positioned on the injector and got good leverage with a big screw driver. I put so much effort on the screwdriver that it started to flex at which point I decided to give up. Unfortunately as I removed the screwdriver the mole grips slipped on the fuel line and bent it at the union that holds the the injector. So now I need a new fuel line
Has anyone had similar problems with 'stuck' injectors or have any further tips? Also does anyone know where I can get 4th injector fuel lines? Seen these advertised mail order - can I get them over the counter and how much?
Thanks for any help
1983 1100 C
1983 1100 C
If you are removing the damaged pipe, you should be able to wiggle and twist the injector a bit more easily in its housing. Might be worth your trying the Mole Grip method again, but with a sturdy crowbar instead of a screwdriver. A block of wood on the rocker will help prevent denting it.
Don't hurt yourself though! Watch out for the Moles slipping. Eyeshields might be a good precaution. :roll:
Sorry I can't think of anything more scientific.
Good luck!
Geoff.
1983 1100 C
1983 1100 C
whatcher need is one of these ::
http://www.blauparts.com/tools/injectorpuller.htm
Trouble is I have never found a source in the UK…Blauparts is across t'pond
There are other suppliers over there…got mine from bugpack via "BowWow"
Under Construction bowwow.ca
have shuftee at page 10 in the.pdf
Mk1 GTI
B5 Passat Estate 5 SPeed
Bosch Lawnraker 32
Bosch Lawnraker 32
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
"Made my own injector puller out of a B&Q fence bracket"
hope the picture helped!
Methinks Rich is going to have a go at sourcing some of these tools when he has half a mo.
At Bugpack there are all sorts of handy tools for we markwoners (and tooers!)
Keep an eye on his site
http://golfmk1.co.uk
Mk1 GTI
Bosch Lawnraker 32
Bosch Lawnraker 32
Might have a go this afternoon if I'm feeling strong as I bent me grips yesterday. And there supposed to come out by hand, :mrgreen:
Any idea how often these seals are supposed to be changed.
Before they go hard and won't come out…doh.
Peter.
1980 1600 GTI, daily driver.
I'm trying to change my head gasket and I keep hitting these little brick walls. Following poor richard's rabit book to the word but I've removed the intake manifold to get a better angle on the bl**dy injectors.
Here's a picture of the one I made out of a B&Q fence bracket
1983 1100 C
1983 1100 C
1983 1100 C
1983 1100 C
Steve
