New here! Restoring Black Mk1 GTI
(In Topic #72847)
Thought I'd say hi, For those that are interested I'm half way through restoring my Black Mk1 GTI 1.6 I brought about 7 months ago… First VW I've ever owned and think I've made the right choice :wink:
Hoping to get it finished for the GTI Sprint day at Santa pod in April but having a few problems sourcing some parts (e.g. Oil Cooler bracket )
I have some pics but will check for the correct forum area before I start posting them in the wrong place! :wink:
Should be respraying it next week… as I've done all the work myself so far (never welded before but it turned out I picked it up really easily) I thought I'd have a go at spraying myself to.
anyhow, think that's enough for a 'hi'
You can post photos in the photo and images section, but they seem to take a long while to be approved. A lot of people stick pictures in their actual post, so may as well do that.
1983 1100 C
1983 1100 C
If I don't have any luck, they're on club GTI's forum so I could post a link to there.
when do you plan to get your white one finished?
when I got it
Stripped down (mostly)
Filler neck + wheel arch replaced
Front end ready for slight filler + spraying
Passenger side wheel arch done last weekend
sorry about the pics… not much of a photographer
will post updates when I've primered it and sprayed it if ppl are interested?
as a bit of advice though, Seriously spend the time finding as much original panels as you can… I haven't and have had a couplt of problems with the pattern part arches and front panel! and the front wings are going to be a headache!
Life Member
I got the arches from euro car parts (they're listing aren't accurate, if you ask for parts showing no stock, chances are they can get them) www.eurocarparts.com
Got the front panel with the car but it wasn't the best of quality, think GSF do them for around ?75 exc. VAT
you got some work to do on yours? any details?
I got one for around ?35 - complete panel and crossmember.
Also had two wings though can't remember how much they were.
They aren't the best fit - they needed a bit of persuasion but once on and painted they look OK.
PS - Car looks like it is coming on nice - well done!
My Build Thread
Life Member
I found the rear arches weren't too bad putting on, don't recommend doing an inner arch if your faint-hearted though, that got me throwing the hammer at the floor a couple of times
yeah I found euro car parts panels to be slightly too short at the rear
got any pics of your LS dubboy?
Great to see yet another DIY restorer. Interesting to hear about pattern panels. I've got a few Hadrian ones ready to use (sill, inner rear arch, floor panels). Had been warned about quality, don't intend to fit them whole rather use them for cutting out repair patches. Thought about pattern front panel(half price of genuine) but thought better of it. Genuine one fitted like a dream, and has the VW/Audi stamps in it
Regarding when I'll get mine finshed, I bought it almost 3 years ago and been doing stuff as I go along. Haven't got the time or space to take it off the road for more than a week at a time, just realised the other day I've done 20000 miles + since buying it - not bad for a 24 year old car.
So far replaced front panel, recon gearbox, lots of ignition components, lots of trim and interior bits and sprayed/fitted rust free 2nd hand genuine tailgate and sunroof panel. Previous owner did quite a good job of fitting new rear panel 7-8 years ago. My aim this year to finally make all the bodywork nice and sound. Need to replace rear arch around fuel filler, patch spare wheel well, ideally new bonnet and front wings and welding on the sills where idiots have badly jacked it over the years :roll:
Few… bit of a long post… oh and 2006 - engine rebuild!
1983 1100 C
1983 1100 C
I also used a hadrian inner arch, was thinking about just cutting off what I needed but thought there would be more chance of me welding it on too high or low (if that makes sense) so took the entire panel out.. just didn't feel right to but up a good/new panel and mould it to parts of the old one bit more work but I think it's worth it
not sure if this was the easiest option but got there in the end and the result is *almost* perfect :wink:
1983 1100 C
1983 1100 C
funny you should say that… I brought the car off a mate who's put a GTI engine in an E reg caddy, he robbed a few bits off the gear linkage, the front seats and clocks (which I've got back off him now).. he was given the car, when I saw it it was a car I just had to save to gave him ?200 for it (probably paid too much but it's got the FD short ratio 5 speed gearbox)
The car's given me a chance to redeem myself on previous incomplete projects (1972 mk1 escort as an example which only needed spraying but gave up and swapped for a Nova *cough cough* I'm a …..) so I will not give up on this!
Is it just me though or is the Mk1 Golf a car that once you have, you become attached to?
to be honest the hardest part I've found so far is the drivers side sill which I've also replaced, I'm too affraid to put the door back on yet in case it's all wrong ops: .. best thing to do is take measurements before you cut anything off, also you can use the other arch as a guideline if anything doesn't quiet look right.
you got any pictures of your mk1?
Looking good PhillTMK1GTI keep up the good work. :y:
I agree I love my MK1 Golf the most out of all the cars I've had.
1983 1100 C
1983 1100 C
And to make thing worse I've seen a black GTI with BBS splits in black/polished rims locally… makes me turn green with envy seeing it fly past me!
Not sure if it will be ready for April 24th (GTI sprint day) but I'm going to try
I see a couple of people talking about gsf and front pannels…. whats there web address???
84 mk2 golf gti 8v
89 mk2 astra gte 16v
82 sirocco GL
84 mk1 caddy
84 mk2 golf gti 8v
82 sirocco GL
84 mk1 caddy
