My mk1 resto
My mk1 resto
Guest user
Carbs4ever said
littlekev …. painted the rear axle with Zingazolv 98%zinc from enginewise.co.uk and then 2 coats of hammerite and then just gloss black paint from an areosol to dull down the glare of the hammerite.. came up well 8)
Zingazolv? cant see it on their web site?
storm81 said
Do you have a direct link to it? cant seem to find it on their site 8O
enginewise.co.uk
Get the 1kg tin not the areosol - the areosol is handi but don't last as long as a brush on tin and the tin is cheaper
Looks like this when put on steel… this was summer last year when I bought a spray tin of it very handi… not as cheap - 1kg tin is way better value
Gotta attack the rust on mine when the weather is better (no garage :cry: )
Guest user
:notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy:
We're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthyWe're not worthy:notworthy: :notworthy: :notworthy: :notworthy::notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: :notworthy: X infinity + 1
nice think! :wink:
Remember, VW made the last car in 1992. After that they started making vehicles.
BTW to do this conversion you need to reduce the length of the threaded bit on the end of the servo and also use the mounting plate that you find sanwiched between the 16v golf bulkhead and servo - this gives the extra few mills of adjustment… quite easy really just have to order up a master cylinder - spose euro cp will be best???
vw-man - I never did drawings as its simple to make - honest! when you look under the car you'll see where everything goes!
Life Member
Life Member
Don't forget to change your badge from GTI to GTC
Looks like another top class job. :notworthy:
Then took it home and buffed it with the wire brush on the grinder - came up tops!
Before:
After:
Then got out the trusty zingazolve and gave it a coat! Rust free block for years to come! Have to give it an enamel coat of black now..
