HELP........ it won't start
Is your spark still weak?
Have you pulled an injector to see if it is firing fuel when you turn it over?
Life Member
Will also have a look at an injectors. Any tips on removing injectors? Aren't the injectors almost jammed into manifold with rubber seals? Think the Haynes mentions removing injectors one by one and placing into a jam jar and watching spray pattern etc. Any other tips?
Dubboy, car has electronic dizzy so I think i'm right in thinking no condensor?
1983 1100 C
1983 1100 C
You should be able to pull the injectors out by hand (they can be tight) or use a screw driver to lever them out - do not force them cos they can be snapped off 8O
Do the jam jar test when you crank it to see if you are getting a spray pattern.
Another test you can do is take the intake off the air valve end and spray some carb cleaner down when you are cranking - If it fires then it will point you down the fuel/spark route i.e. if it does fire then problem is fuel - if is does not fire the problem is spark.
The other test is a compression test - do that just to be doubley sure.
The engine has to have all three - spark - fuel - comprssion - one or more of these is missing from your motor
Life Member
1983 1100 C
1983 1100 C
Warnings
- it's not complete yet
- use your browser 'Back' button if it opens in the same window, to get back to the Forum
When it's complete I will have a .pdf file for download.
I do NOT accet any responsibility for mistakes etc. at this point - it's not finished !!!!
Injector Test
Couple of little questions. Firstly, when you switch on the fuel pump with the home made switch has the ignition got to be on? Second, when you grease the new injector seals upon refitting do you have to use a certain type of grease?
Cracking article though mate. I guess it's a test we should all do on our Gti's and with your article you've made it look quite simple. I would have shyed away from this myself before! ops:
Again, nice job! 8)
Hairyarse said
Prowler, that's one cracking 'How To' FANTASTIC!!
Again, nice job! 8)
Thanks Hairy, and for asking very relevant questions. These will need to be addressed in the final version - I did not think of the obvious q's.
1. Ignition is OFF, keys out.
2. Any high melting point grease - it's just to keep the seals lubricated and makes later removal much easier
3. It IS simple, just take your time. I've got it down to about 1/2 hour from start to finish (but I can do it blindfold now )
I must state clearly - USE NEW SEALS. possibly replace them every year or so, they soon deteriorate (although ones I got from VAG seem to be better).
I composed the whole thing because all sorts of 'experts' were telling me my metering head was knackered, but I 'felt' it was injectors - I proved them all wrong using this method - 2 sets of dodgy injectors !!
IF ANY ONE ELSE HAS ANY COMMENTS OR QUESTIONS PLEASE ASK, I WANT TO GET THIS PERFECT.
alexh said
prowler i wish i could have put it that good. same as yourself i have used this method for years but braveley without the bottles as you get cocky with experience. i learnt this method from the vag official dealer manual
…learnt it from the boss of MobileTuning…
…and I'm supposed to be a Technical Author when I do any work….
Have now got it linked into the tips page on my website…
Injector Test
and will start a new topic, as not everyone may be following this one….
Dubboy wrote:
you may have a blockage in the fuel dizzy
Top prize (a broken metering head :twisted: ) go's to Dubboy. Looks like I need a new metering head. Aren't these quite expensive new? Mechanic's trying to source one second hand. Whats a good prize to pay?
1983 1100 C
1983 1100 C
Life Member
1983 1100 C
1983 1100 C
Managed to clean one up (from Blackman's near Maidstone), by disconnecting injectors from pipes, disconnecting filter, emtying it and meter head of fuel and filling the lot with injector cleaner, reconnecting everything except injectors, switching on to pump a bit of fuel to push the cleaner into the head and it's valves, let the lot sit for a couple of days. Then switched on to push a couple of litres of fuel out of the pipes (came out grotty at first), put injectors back on, put them in and it's still ok. Keeping my old one as a spare just in case (was the injectors that were knackered after all).
May be worth trying first.
1983 1100 C
1983 1100 C
