Mk1 Caddy Pickup aka Patches
Honestly, I’ve worked with steel and top fabricators/welders over many years Rich and your work on this Caddy is second to none! Keep up this great work my friend
Dad and I discovered the drivers side needed quite a bit of work. The inner and outer sill, floor, centre seat support, behind the seat rail and at the front bulkhead at the bottom of the A pillar.
Got all those repairs in. Next finish the floor welding and then start on the rear cabin panel and bed.
Made some sturdier chassis floor supports:
It's made up of 3 parts. The lower embossed panel and 2 upper panels which form the base of the screen.
This is the final piece of the puzzle and will finish the cab.
Top work again
Dad and I finished the internal window panel:
Both sides were crusty but not overly apparent .
That tiny spot of rust at the bottom of the seam was the tell-tale sign something was amiss .
Last edit: by Rich.
Version 1 of the outer skin:
Version 2 with sharper swage lines .
Last edit: by Rich.
There was a dent in the outer skin above where it needs to be made so constructed a tool to use with a hammer and got it straight again .
