Overheating - 1983 GX
(In Topic #220953)
I'm new here as I've only had my golf for a week.
Other than the long drive home along the motorway I've hardly used her but I've been out to the shops today and come across an overheating problem.
As you expect, if pottering about things seem ok with the needle around half way on the temp gauge (doing 50mph brings the needle just under half way).
I got stuck at a train crossing so was sat a while and I noticed some steam coming from the bonnet where the expansion tank is located and the temp gauge was maybe 2mm over half way (no light on, but it works).
I got home just fine and let her run whilst sat on the drive as I wanted to see if the rad fan was working, it was and it brought the temp down whilst idling.
Any ideas what could have caused the overheating?
Coolant levels and the colour is good but I can't say how long it's been since it was changed.
All help appreciated
Old coolant wont make the car over heat it's probably something like a sticky thermostat, I would get a new thermostat and you will need to replace the coolant anyway when you remove the thermostat.
Not sure what size engine you have in the GX but if a big block 1.5, 1.6, 1.8 then this thermostat.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-parts/cooling/car-cooling-parts-and-car-heating/car-thermostat/?209440040&1&c01e4844afd3a7f2e3f03130e2053c29a40e4e54&000325
Blue coolant and its ready mixed, 5l is plenty.
https://www.eurocarparts.com/ecp/c/Volkswagen_Golf+Cabriolet_1.8_1989/p/car-accessories/engine-oils-and-car-fluids/antifreeze-and-screenwash/blue-antifreeze/?523770501&0&cc5_865
Sale on this bank holiday weekend so don't forget to use the discount code and if collecting from a local store use click and collect to get discount as you don't always get it when walking up to the counter.
Blue coolant will be fine for small block cars, 1.1 or 1.3 but check the thermostat as I'm not up on those engines…
Another thought over cooling…
Airlock in coolant system? Do you have an expansion tank or top fill radiator?
Last edit: by mark1gls
Expansion tanks can leak.
I would say flush and back flush the cooling system, then replace the t-stat. Drill a 1/8 to 1/16 hole in the lip of it and you won't have to worry about a bubble in the system.
Check the radiator core on the inside of the fan shroud to verify that you don't have a seam leak on the radiator matrix. I just found one on mine, and the radiator is only about 12 years old.
Check the condition of your hoses and if you are using the old green type of coolant then you can use a UV light to verify that all is well as the Green stuff glows under uv, and I have found many a water pump leak that way.
If it had you'd of dumped most coolant on the road and needle gone to max.
Mine did it on the MOT tester but I had a fan issue
If your fan is working then it can't overheat but I would suggest your expansion tank cap is knackered, you'd be surprised how much coolant you can lose out of one thats had enough.
I had the same thing on my last proper drive on Sept 30th last year
Current rides:
I got my coolant system from brown to crystal clear before I finally filled with coolant again
Current rides:
I have two spare new expansion tanks for some reason so I will swap one out next week.
I'm also thinking I will just give the coolant system a good service and do the T-Stat and flush, I have a week off from the 13th so it will keep me entertained lol.
Thanks everyone!!
I will tell you that cleaning the t-stat bolts is a good thing, coating them with never-seize before going back is also a must. But the biggest hint is to use a torque wrench when finally replacing the t-stat cover and if yours is Plastic get a new one….use a torque wrench to put the 87 in/lbs of torque on the bolts, as they are steel bolts going into aluminium and strip very easy with over torqueing.
https://volkswagenownersclub.com/vw/showthread.php/21399-How-to-flush-your-radiator
Regional Host NE
did it not over heat surely coolant is
just water the stat surely is not going
to fix its self probably be opening temp
around 88 degrees c so half way on the
gauge would be no where that temp.
At Idle the heated engine compartment air collects at the top of the bonnet. When your fan comes on, it is pulled through the opening of the uncarded radiator, and over the Matrix Heating up and not really cooling the fluid.
See this thread on Engine Compartment temps.
Debunking the Cold Air Intake myth | VW Vortex - Volkswagen Forum
Also on a functional system you will see that when the radiator fan is running it draws the rubber mats in to the shroud closing them, to redirect the air through the shroud if the upper card is off it will not shut them completely…when you are driving, they are forced open to allow total cool air over the whole matrix.
Yes I smoke tested the airflow in the engine compartment with a Halloween smoke machine and my bore scope camera one after noon years ago….with a upper card installed and one missing (YES I WAS BORED.).
No upper card on a new to me car.
After Brianizing
nicci21paul said
sounds very complex did it over heat
Would be pretty much halfway, bit harder to tell on the Mk1 because there is no numbers on the gauge but on pretty much all cars halfway on the temp gauge is 90 so its probably right.
Oh thats another thing, check your t-stat and your fan switch are the correct ratings
Current rides:
Regional Host NE
did it over heat
Regional Host NE
make a cuppa
Regional Host NE
out it must be boiling over
relief the stat has turned it
off
The coolant under heat would start to leak out and drip onto the exhaust manifold…..not much coolant at all but enough to cause lots of steam so it looked much worse than it actually was.
The bad news, the thermo housing is knackered too, sooooo fragile.
It looks like the part no longer exists from what I can tell (035919369), any ideas of an alternate solution?
At the moment I've ran a hose to bypass the housing and all is running ok but it must have been doing something so I would rather it be connected lol.
Kit if you don't have the thermostat already.
https://www.ebay.co.uk/itm/VW-GOLF-MK1-CABRIOLET-MK2-GTI-THERMOSTAT-COVER-KIT-C584/220983985218?epid=1043807109&hash=item3373ac0442:g:i2kAAMXQwKdRfjLq
Or the thermostat housing.
https://www.ebay.co.uk/itm/Mk1-2-golf-thermostat-housing/351995497089?hash=item51f4910a81:g:33oAAOSwuxFYuEjr
VW changed over to the plastic type for later cars I guess to save money, if yours is metal you cant buy new ones in this country only 2nd hand.
mark1gls said
Do you still have the original carb or has one fitted a Webber carb?
One has the original sir
