New to this golfing lark!!
Just bought a 91 clipper, so I thought I'd say hi!
There’s a pipe from the vacuum advance off the distributor.
It goes to the other vac pipes at the yellow plastic joint.
Airbox to rocket cover breather.
There’s usually one in the rebuild kit.
But I got some gasket paper from the car spares shop and drew round it.
However my old one was serviceable.
Deffo get a new rubber flange though.
Pointless rebuilding carb to find the rubber flange isn’t any good.
Guess how I found that out lol.
Found my misfire problem (one of the main carb studs is threaded and the nut just spins so it’s dragging a load of air in, removing the washer enabled me to nip it down and cure the fault temporarily) but still want to service it properly.
Seller was called fastroadcar on eBay £26.00 inc post.
One of the fixings is a stud you can pop 2 nuts on tighten up against each other to lock then tighten down.
I’d put a new rubber base mount on too.
Then you know you got years carb trouble free motoring ahead.
Also changed the plugs as it had 4 completely different ones in it (some people shouldn’t be allowed spanner’s!!!) and a full service, engine gasket set and clutch ordered ready for engine removal.
Work on my Clipper
Work on my Clipper
