Audi tripple VDO gauges install guide
What a nice place to stay for the winter, under a nice carpet and everything, looks great
for voltage on CE1 fusebox use G spade 2 or 5 as those are fed from coil power rail from ignition switch, so useful to keep an eye on. spades 1 and 5 are fed from the X relay so only really tell you how much power the wiper & blower motors have to play with ceramic fusebox you can use G spade 3 round the back.
remove all that garbage in your dizzy vacuum line, its not supposed to be there. it should have a plastic vacuum pipe with rubber at each end direct from the nipple on brake servo hose. I suspect in the past someone has had a pipe snap/melt and fixed it up from bits and bobs pulled out of the bin…
But dont all the grey/blue connect to lighting dimmer? Would make sense if they did and then Grey/red was constant on ign.
I’ll definatly look into the waccum stuff, only thing that confuses me is that there are these rubber endings in place but maybe the plastic hose was too short for them in the end.. they tend to often have quite a past these cars
BTW this is up next
grey/red on ciggy lighter is permanent live so no good for the gauges, but the brown is earth so you could tap your gauges to that if need be, but may as well run the earths to the earth claw
