new to me 1992 golf Cabriolet
on a different note. where can I find new lightbulbs for the instrument gauges by the shifter?
So far the shifting has improved a bit. It's still a bit vague. and second gear likes to hang a bit in downshifts sometimes. as well as the first likes to end up in reverse sometimes. Oh and 5th gear likes to be directed well or it likes to down shift to 3rd.
Should i get an entire shifter kit or would the bushes be ok? How much of fine tuning would I have to do afterward to get the gears go in smoothly ?
I also plan on getting some redline 50305 MT-90 75W90 GL-4 and replace the transmission fluid.
maybe that will help too.
You shake the hell out of the engine let it settle, then do it again…. Once it settles then you tighten down all the mounts.
It is also a good thing on the front valance mount to loosen it and shove a couple of flat washers between the cup and the mount…One side then the other.
It tends to tighten that mount up and reduce torque loss on the engine when you rev it.
Now you can replace all the shifter links and bushings.
and adjust your shifters per the how-to on www.cabby-info.com.
If you add a short shifter and a weighted billet to the rod, then you have more fun shifting and get a more positive feel on engagement.
Yes the right side mount is a large PITA… I have been dealing with that since 1982 on a Diesel Rabbit.
Missinglinkz sells a cost effective short shifter (bolt on) and a weighted billet… he ships overseas…. I had one on my manual Cabby, and enjoyed the heck out of it, and when my wife rode in the car, her leg wasn't in my shifters way for 5th… I guess it is different of you are single.
Funny thing all the instrument and gauge lights stopped working. Fuse seems good and so does appear the switch. Hmmmm got to investigate more. It was late yesterday when i got home and i was tired. Is there a common failure point?
To Validate that all the lights are good
1. make sure that your gray/blue wire isn't burned up Very common thing.
2. the 90ish cabbies have a fused console light switch so measure the voltage on both sides of the fuse Key in and the switch turned on. To validate your fuse is good.
Make sure your Dimmer roller is all the way up…. have moved it by mistook once or twice.
Test it 2 ways.
Ignition switch off key out, headlanp switch off.
Take a 9V DC battery and apply the + lead to the Gray/blue wire and the Negative to the frame. Do your lights light? back side of the headlamp connector
You can also take a +12V wire from the battery and apply it to the gray/blue wire on the back side of the connector to see if the lamps all light.
You are by-passing the switch and dimmer to validate that all your bulbs didn't fry at once time due to age.
Usually if all the lamps go out at the same time you either have rolled the dimmer all the way down, or the switch is bad… Briano's rule of thumb.
Ill get a new switch at the junk yard although. Do you have the pin out for the switch ?
Fuse 20 10amp… that's why my lights don't come on.
thanks
AllMacs said
Fuse seems good
Seems and knowing it is good are 2 different critters…
I have seen ones that don't look blown, but the meter doesn't lie….
AllMacs said
Today my dash went out intermittently . I guess the 10c voltage regulator is the next thing to be replaced?
Or your 14V or Ground is intermittent. Look at my thread on plumping the connector, verify that the pin 14 and pin 2 are 12V and ground, then test the 10V stabilizer, but that 10v Stabilizer only effects the water temp and fuel gauge.
I had a pin curl up on pin 14 Black 12V in that It layed flat when I remove the connector and scrunched up when I returned the connector.
I have a thread in the how to's (link on signature) on back feeding voltage to the cluster.
Someone replaced the bolt that holds the speedo cable with a different M7 hex bolt. Can you tell me how long the bolt normally is supposed to be?
this one seems rather short.
Last edit: by AllMacs
N 012 234 5
Seal: 171957861B
Take care not to drop the gear in the Transmisison, there is a "C" clip that tends to fall off, and if the gear comes off then you are looking at fishing it out, or a tranny overhaul to get it out, yes it is but a plastic gear, and yes the tranny can chew it up, however: It's bits can get stuck in the syncros..Causing a more massive rebuild than just getting it apart to remove the gear and clip.
When I have done it in the past, as to Fill the tranny…. I have jacked the car placed it on jack stands, car in Neutral, then rolled the wheels a bit one way then the other to make sure there was no pinching of that gear by the diff drive and it came out easily. Some have had to pry, pull and struggle…. me I have never found that to be the issue if I made sure there wasn't a bind in the Diff.
Last edit: by Briano1234
About that bolt… its not a hex bolt originally, correct? More like the bolts for the motor mounts?
