Anyone fitted a new headlining?
Re:
Pete M said
Hi. You are absolutely correct,  trim the tubes as required, make sure you leave enough material to maintain the stitching.
Sent from my E5823 using Tapatalk
Many thanks :thumbs:
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior.  daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
An update.
I removed the windscreen myself by tucking the inside part of the seal under the spot weld lip a little at at time, starting in the top corner and then equal amounts each side of the start point, took about half and hour.
The headlining I found quite easy to do using the instructions you guys recommended and the 3M Refit tape. I would have really struggled with contact adhesive, spray or from a tube.
I attached about 6 inches at the front and then the same at the rear, the completed the windscreen area. After that was complete I did the sides and finished with the rear C pillars.
I found i quite straightforward and would say if you have the patience and use the tape go for it.
Thanks for all the help folks.
262A8FCB-348B-480D-B47F-7A5D4B4DD02B.jpeg 14E9F9AE-A4CC-4AE5-AE25-6029B4C67255.jpeg DAC04757-C0F2-48BC-8331-891A4861DAD4.jpeg
Re:
Brilliant well done, glad you used the 3M fixit tape, looks a good job done.
The tape will be very useful for other jobs in your restoration.
Malcolm
