**wanted** HELP! 1.8T build thread for mk1.
NEWbie with the 1.8t
https://vwgolfmk1.org.uk/forum/index.php?page=topicview&id=specialist%2Fmodifications-and_2%2Fengine-mount-query-1-8&=
What do people do with tiding up the pipe work (coolant and vaccum pipes)?
looks like a mess but i feel like some of it can be deleted or replaced with decent aftermarket part?
Would be handy to see what people have done and read there ideas.
anyone had a little issue with the fitment of the cambelt after fitting the manual tensioner? everything is done correctly and the engine turns over lovely but the belt of the camshaft gear seems to move off the gear slightly when you have turned it over a few times. the only difference is ive fitted a 9mm spacer instead of the mentioned 8mm. but the belt sits well in the middle of the tensioner pulley so its not getting forced to one side.
just abit confused….
thanks
The usual culprits are the Tensioner stud isn't truely at 90 all way around if it is terribly off, but a wee bit of movement isn't a killer as i never have seen one that is truely centered it is aways a wee bit off.
Briano1234 said
There is some movement while the belt seeks centerline.
Alright cheers dude, I've sorted it. I got the spacer machined to 7.5mm and the belt sits on the cam sprocket lovely now.
I've got the gear box mount and rear gear box mount fitted great. Just struggling with the Epytec front gearbox mount (bolts on to front panel) it's a long way out for getting the two bolts into it to bolt it to the front panel… anyone had issues before?
Plus I'm fitting a Epytec reinforced engine mount as I only had the small block in this engine. I want to get the front mount on and secure as the throttle body and manifold seem to abit in the air. (Read alot of people having the same issue) just wondered if people had any updates on the issues?
Cheers guys.
