02J swap, reversing light issue.
(In Topic #216293)
What am I not seeing?
1983 MK1 Golf four door 1.8T 20V BAM remapped, MK2 dash and loom, TMI interior. daily.
2014 VW California 5.1 with full Sportline kit, weekend home.
Hope this helps :-)
you could even hook up a pressure switch inside the car near the gearstick that gets hit when you put it in reverse
I can see a sleeve and seal on the Audi parts and mage but not the white nylon sleeve for the plate with the two pins in it!
John, defo want reversing lights, I've got the hydro clutch conversion (think it's a CQ's) so hopefully it'll fit. Only want them as people expect to see them, pedestrians and drivers alike.
so yes all you have is the 02j alloy shifter housing, you need all the rest of the parts to go with it. the linkages on the side, the TT shift weight to go on top, the selector rod thing that goes inside the tower with the threaded bit on top to attach the weight on etc as all the 02a parts are different
Mine size the one with the grooves around the shaft, I don't have the collar that is on the shaft close to the housing but everything else.
are there any part numbers visible on the shaft
Hope, not numbers
Just off to the local VW and Audi dealers with a Post It note full of part numbers … wish me luck
Heeeeeeelp!
Last edit: by Pete M
