83 gti 16v
83 gti
rod bearings look fine
I also took the crank out and as suspected it looks fine, anyone got any ideas where the random bearing material was from as I haven't a clue.
not been doing that much on the golf recently but did have time to make up some boot panels
off cuts of the wood used
made lots of shavings
ended up like this
I did swap the pedal box for a cabby one so now has a pedal mounted brake light switch, will be using the cabby engine bay lighting loom to keep it tidy, luckily it has the outside temp sensor wiring so no need to change anything
the wood is chestnut
Hiya,  those wheel centres, I'd be interested in buying them if you choose not to use them 👍
I have the same compomotives in 15" for my red gti.
Cracking project by the way.
yes i would sell them if you are i interested
Have messaged you pal 👍
