Main beam warning lamp
Wire up a replacement.
I will continue diagnostics when I get some spare time!
Is it intact and working or partially removed/bodged with Scotch-locks and spare wires everywhere??
Thanks for the information above guys, this will be a summertime job testing it all
Luckily my MOT guy loves his classics and hasnt questioned it, at most it would be an advisory.
Alps 1992 Rivage Green, 1991 Rivage Blue (SOLD), 1986 GTI convertible White (SOLD)
the issue seens to be with the stalk, there must have been some dirt or something in between the contact that has cleared itself!
1990 Singlecab 2.1 manual
Now to the question:
Mai main beam blue indikator not working. And I tried 2 different cluster units it seem that I am geting 10.4v from the 2 and 7 pins… is it ok or it should be not les then 12v?
And is it meens that I will conect the same 2- and 7+ pins on to the cluster itself with a 12v the blue light should come on?
Pin7 should be blue/white, but it will only light when you flash the hi's.
Make sure your fuses f9 and f10 are good, and you are not reading a feed back from the main lamps.
Last edit: by Briano1234
10v should be enough to light the bulb as said, though if its old the bulb may be blackened on the inside which wont help if your voltage is also low.
the main beam indicator is fed from fuse 9. if both main beam lamps are still working it could still be blown and you have a relay loom taking over the lighting in the engine bay which is fed from the other side or some bodger has tapped a power over from the other lamp to bypass an issue
So will have to check all my connections and wires… but it is still strange that I do get the power to the 7 pin with the high beams on and to different speedometers units is the same… 🥸
Eigelis said
Thanks guys for your thoughts…. I fixed a lot of different issues with my power…. But the blue light is still not working… i did change the speedo from motometer to vdo because the clock was gone on mine… but the main beam lights blue light was not working on the old one to…
Have you checked the bulb itself isn't at fault?
