Audi 80 VDO Gauge Installation on MK1 Golf GTi
https://www.ebay.co.uk/itm/OIL-TEMP-TEMPERATURE-SENDER-SENSOR-1-PIN-180-C-FOR-AN-AUDI-A4-A6-A8-80-100-NEW/182696766392?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2648
And the pressure sender from VW Heritage, possible this one! I'll check my paperwork tomorrow and let you know.
https://www.vwheritage.com/v360023-oil-press-sender-150psi-gauge-6-9psi-switch-2-pin
If I disconnect the wire from the sender on side of engine block, then the MFA flashing oil light turns off.
The temp sensor is exactly the same one I purchased from eBay. Also coincidence it is the same seller.
However the oil pressure sender (twin pole) which goes on the side of the engine block is an Intermotor (P/N: 53903). According to the manufacturer website it is alternative to VAG 035919561 with a rating of 0.3 bar & 5 bar. I bought on eBay for around £25 brand new.
I have a suspicion that the oil pressure gauge is faulty or incompatible. I have raised a case with the seller anyway.
The VW hertitage one you are referring to may be the way I guess.
The one I took out on side of engine was the 0.15 bar to 0.45 (P/N: 056919081C)
I got the negative from the ground point on right side of fuse box and the positive from the fuse box which switches on/off with the ignition.
I'm thinking of trying again but taking direct connection from the battery just to test to see if it makes a difference.
I fed my gauges from the same place as you. It sounds as though your sender is working the opposite way to what it should do!
Hi Saulty,
The pics show what I get. Red light keeps flashing. When cold oil pressure is almost zero and when engine is warm, it shoots past 5 bar.
Can you confirm where you purchased the sender unit from? Was it VW Hertitage?
V360006 Oil pressure sender, 80psi gauge, 6-9psi switch, 2 pin
00001 @ £00042.02 GBP
I've not had any trouble with it in the 18 months it's been fitted.
https://www.vwheritage.com/v360006-oil-pressure-sender-80psi-gauge-6-9psi-switch-2-pin
They've gone up quite a bit since I bought mine. VWH seem to have got expensive lately, you might be able to get one a bit cheaper but I think you get what you pay for!
When warm, I run at 6 bar at speed which drops down to 3 bar at idle.
With oil temperature, I have fitted the temperate sensor in the engine sump drain plug using an adapter. I have a 150 degC gauge fitted with the 150 degC temperature sensor.
It takes some time for the oil in the sump to heat up. On a long journey it runs at about 80 degC which is similar to modern non GTI engines that I have which seem to be fixed at 90 deg C when warm.
Doing it this way negates any impact on existing Instrument and MFA indications.
if you earth the oil pressure gauge wire it should sit at 0, if you disconnect it should go to max as you have seen. with the oil pressure warning switch, if you disconnect it the light should never come on, if you earth it the light should flash
I purchased the senders from VW Heritage (more expensive but should be the right ones).
While tidying up the wiring, found the heater matrix leaking so ordered that as well to the Christmas Gift list for myself.
Part Numbers ordered:
VDO OIL PRESSURE SENDER 80PSI 2 PIN
WITH WARNING LIGHT M10 X 1 (SKU V360006)
£59.70
OIL TEMPERATURE SENDER INC SEAL,
WHITE 1 PIN (SKU 049919563A)
£6.70
HEATER MATRIX (SKU 171819031)
£21.50
Will post an update once installed and tested.
The sender unit from VW Hertitage worked a treat. All gauges are working sweet.
Conclusion is that don't buy cheap ones from eBay. If you want good senders, buy from VW Hertitage even thou its expensive, it's worth it.
They were dull yellowish colour.
Easy to fit, just need a soldering iron, electric tape and 3 super bright LEDs (5mm) from eBay. Make sure that the LEDs are supplied with the resistors which make them compatible to 12volts.
You pull out the old bulbs and can use the existing holders to feed the led through and then solder the resistor and wires. Or you can just buy prewired LEDs with resistors fitted and put them into the hole at the back of the vdo and tape it. All the LEDs you need to solder in series which connect to the interior dash lights.
I had white LEDs but they didn't look nice so switched to green to match the dash. The LEDs are extremely cheap, just a couple of quid.
If yours is red then it probably due to the red plastic filter inside the vdo gauges. Mine were already removed and it's a risk trying to take it apart. I see from forums that some people pry the ring off it or cut the vdo casing and then super glue back but it won't be perfect unfortunately.
I have never opened so do not know what is involved. You can have a look, but don't take risks otherwise you can damage the gauges.
I also did an LED upgrade of all the interior lights, took ages, but you notice the difference immediately
https://www.brickwerks.co.uk/accessories/gauges-and-senders/vdo-sender-oil-pressure-5bar-0-25bar-m10x1.html
