1990 cabby fuel leak
Merchandise Manager
Do you know what size clip I should get? It's got 7-9mm or 8-10mmmark1gls said
No clips like this as you reuse them, ones in your link are again use once clips.
Shop around as 1st link I found. Most motor factors will sell them or you can pay over the top prices at Halfords if you don't have a local independent motor factors. http://www.ebay.co.uk/itm/ASH-W4-Stainless-Steel-Mini-Metal-Nut-Bolt-Fuel-Hose-Clips-Petrol-Pipe-Clamps/201979592601?_trkparms=aid%3D555019%26algo%3DPL.BANDIT%26ao%3D1%26asc%3D20151016114640%26meid%3D7254bb073b084a688626a594e9662cf2%26pid%3D100507%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100507.m3226
I would keep your fuel sender as they are expensive just be carful twisting it as the plastic can break.
I cant find an image but even a U shaped bit of wood may work, they are not that tight once they start to move, worse case but you may break bits of plastic is use a hard bit of wood and hammer to turn the sender but not the best way.
A bit like fig 8 in this link..
Audi A4 1.8T Volkswagen Fuel Pump Replacement | Golf, Jetta, Passat & Beetle | Pelican Parts DIY Maintenance Article
