1981 GTI Irish Rebuild
Full restoration...
Re:
It's from gasteros plating and I bought the power supply separately. It's a bit of a ball ache getting it to plate properly, especially with the yellow passivate… All parts are brought back to bare metal using the sand blasting cabinet and then decreased using a highly alkaline solution then zinc plated.LaluOC said
Standard gti as far as I'm aware. Thought they all had brake linkages like mine ?!
Regards Volkswarren
Panels needed:
- Front Panel
- Front Apron
- Inner Wing NS/ & O/S
- Front Side Member N/S & O/S
- Battery Tray
- Floor Pan Left/Right
- Inner/ Outer Sill Left Side
- Rear Panel
Unbelievable amount to filler covering large holes that weren't visible before, this was done by the last owner…
Also thinking about deleting the sunroof, and replacing it with a new skin/ cross beam. Has anyone any experience of doing this ??
Anyway, I'll let the pictures speak for themselves!
Last edit: by LaluOC
Re:
Can be picked up on Amazon for roughly £30Webby! said
Cheers. I'll get one of the kits. What power supply is needed? Quality results, hope I can match them!
Re: 1981 GTI Irish Rebuild
Small progress to report:moryan said
Anything more on this?
Mostly been waiting on panels to arrive.
Replaced since the last post
- inner and outer front wings including chassis legs.
- sills and floor chassis strengthening legs
- front and rear panel
- floor panels left and right
Sunroof has been a major issue. The sunroof tray was rotten so a new one needs to be sourced. Found a mk2 tray in better nick that I'm collecting on Monday.
Ordered all remaining parts needed to build the bbs rs001's. New bolts and dishes.
Also got my hands on some OEM+ KW v1 coilovers.
Powder coated the centre piece, new raw stainless steel bolts, original centre locks and schmidt lips. They'll be original 7j et25 RS001
Re:
You absolutely need a power supply. I very the current quite a bit which you won't get with a battery and resistor. Cost me £35 which is cheap considering the results. If you sanded and polished the metal before playing you also get a great plate. My advice is get a controllercdgthreesalmons said
Fabulous results with your plating! I have been trying do similar but struggling to get a good even finish with the plating. I have the same kit from Gastero plating but use a battery charger to provide the power and the simple wire current controller - but the finish varies alot and the wire current controller keeps burning out!!!! . Does the variable power supply help do you think? Any advice greatly appreciated as your results are amazing!
LaluOC said
Time to start piecing together some of the jewellery for the build!
love those wheels
Re:
love those wheels
