Mk1 g60 wiring guide ?
I'll adjust (with spade terminals) and wrap the wiring properly once it's working
Thanks again for your help 👍
I have altered the wiring as mentioned above and I'm still stumped
The brown/yellow from the ecu to the fuel rail is putting out +12v with ignition on and cranking, not a pulsed negative.
I even tried my spare ecu and it's still the same.
Also the large N terminal on the fuse box is only putting out +12v for a brief moment while cranking (regardless of how long I'm cranking for).
Something is amiss here and i can't figure this out . Any ideas?
That's when I found the brown/yellow putting out positive 12v (testing between that cable and the battery negative)
Something isn't right,
1 - red/green - cranking live - spade on c/18, or tapped to starter red/black
2 - purple - lambda probe pin 4
3 - blue/yellow - fuel relay trigger - D/13
4 - white - knock sensor pin 4
5 - blue - inlet air temp/co pot pin 1
6 - brown/white - sensor common earth (tapped to various sensor brown/white wires)
7 - yellow - knock sensor pin 2 & 3 (earth and shield)
8 - red/black - distributor pin 3
9 - blue/white - inlet air temp/co pot pin 2
10 - brown/green - ecu coolant temp sensor pin 1
11 - red/blue - idle switch
12 - brown/yellow - fuel rail plug pin 2
13 - brown - earth to battery
14 - black/yellow - ecu relay power & ISV - to relay above fusebox
15 - blue/black - WOT switch
18 - green/white - distributor pin 2
19 - brown/white - earth to head
22 - white - ISV pin 3
24 - green/yellow - rev counter - ignore
25 - green - coil trigger - coil negative
There are a couple of different colour wires in my loom from above but it was running this engine and loom in the donor car (golf mk2 country, chrome edition of all things).
I do have another loom that I believe is corrado g60 so I'll compare that against your list above.
I'll do a pin list of what I have in the car when I get chance and post it up to compare to yours.
It's got to be something trivial. .
I'll keep you posted, cheers, Karl
1. Red/green have tapped to starter red/black.
2. Purple.
3 red/yellow (not connected as the red to the fuel rail is in the large 'N' terminal on fuse box ).
4 white.
5.blue.
6. Brown/white.
7.brown/screen.
8. Red/black.
9 blue/white.
10. Brown/green.
11. Red/blue.
12. Brown/yellow.
13. Brown.
14. Black/yellow to fuse box spade terminal marked 'G'
15. Blue/black.
16. -
17. -
18. Green/white.
19. Brown/black.
20. -
21. -
22 white
23. Black/white.
24. -
25. Green.
I have the red/white for the isv in with the red yellow spare fuel pump spade terminal above the fuse box.
All connected like this I'm getting +12v on the brown/yellow cable for the fuel rail which is what's throwing me
I've also changed the fuel pump relay number 62 to a number 18 as suggested to get the N terminal live on ignition to make it easier to test
Last edit: by sweetmk1dub
the black/white is the extra ecu relay feed found on some later G60, its not needed but ifd you do wire up a 30 relay above the fusebox it goes to pin 86a
the red/yellow in pin 3 needs to go to D/13, then you can use the correct digifant 67, 80 or 167 fuel pump relay in slot 2
when I checked over the wiring I had ballsed up by putting the green coil trigger with the black cable on the positive side of the coil.
I've now put it right.
I'm hoping that I haven't knackered the ecu by doing this and it's what is causing my pin 12 brown/yellow to give out +12v instead of the negative trigger it's supposed to. (If I can get pin 12 operating correctly the damn thing should run, albeit poorly as I haven't yet fitted a lambda )
Will keep you posted. 👍
I sold my old corrado g60 about 9 years ago and a lad from work bought it a couple of months back so I'll try my ecu's on that car at some point this week
I'm actually hoping for duff ecu's as at least it will stop the head scratching
First just used my tester on his fuel rail and I'm getting the same readings as my own car so even though it's not reading what it should (probably my old fluke testers) I know that mine should work.
When I tried my ecu's on his car, one worked and the other didn't.
Next step is pull the fuel rail apart to inspect the loom inside
My brown/yellow negative trigger from ecu pin 12 goes to the red cable in the fuel rail loom.
My red positive cable to the fuel rail goes to the brown cables in the fuel rail loon
This hasn't been changed since it was fitted in the donor car though.
Loom in the fuel rail looks perfect, hasn't gone brittle
on my g60 diagram it shows ecu earth to pin 2 of the 2 pin plug, brown on injector harness. live from fusebox is on pin 1, red wire on harness.
I'll leave it as is though as it hasn't been changed since running in the donor.
I have ordered the relevant fuel relay and ecu relay and will be putting these in next.
If that doesn't get the injectors working properly then Im stuck
I'm leaving the k-jet relay fitted in slot 2 and just putting an extra relay above the fuse box purely for the fuel rail positive.
To be triggered by the red/yellow pin 3 on the ecu.
I'm not getting 12v on this red/yellow while cranking and coupled with no negative on the brown/yellow which gives me even more reason to think that the ecu is knackered 🙁
Im sure this ecu has an aftermarket chip fitted and I have a standard chip in my toolbox so I'll fit that when I get chance just to rule it out before buying a replacement ecu
I really don't like car electrics
30 - live
85 - ecu pin 3
86 - ignition live, D/2, D/7 or G spade 2 or 5
87 - to fuel pump/rail/lambda
with a fuse on the live or fuel pump pin
