Problems with power
AVS Car Parts - [The VW - Audi - Seat - Skoda Parts Specialist]
get new leads as well if old or unknown make
anyone know can i get that part separately from somewhere ?
Last edit: by Petrif91
With it unplugged, you simply use a DVOM, and measure for a short/open when the Throttle Butterfly valve is open/closed.
This is only applicable to the 90ish Digifant.
Bigger issues are Timing, and Vacuum leaks.
this doesn't test the idle switch itself, as above use a multimeter or a test light for that
Any ideas what is the right colour for the sensor, because when i look them i get usually green ones, but this one that i have is white one ? any differences ? Knock sensor should do something to timing and other stuff ? Because 98% times when i start the car again it runs great a while and then the problem starts.
Petrif91 said
New knock sensor coming, lets see what it does, grounds are also looking nice and clean. Is there a way to test the fuel pump relay and pump ? Because i dont hear a loud noise from it so maybe the relay has problems ? Oh and been looking pictures and in many cases the blue coolant temp sensor is the nearest one to the block and mine is not ? Does this even matter where it is. See the picture i sent earlier.
IF you can't hear the fuel pumps Prime for 4 seconds prior to start, then suspect the Fuel Pump Relay first.
otherwise you don't hear the pumps run normally, just the initial prime, that is turn the key to run, not start will all the accessories off, and you should hear them run for 4 seconds.
The Blue CTS sensor doesn't have a preferred location, it could be in the front of the flange or to the rear of the flange….Just make sure that you have the proper plug on it, blue for cts, and black ro the Water temp senor.
Hint, You may want to buy a new flange and keep it spare as the plastic ones break at the mounting ears at the most inappropriate time.
or
You can replace the plastic flange, with a metal one, and use the CTS, sensor off a 16V and a temp sender. (best thing is they never break, and the 16v CTS seems to be better made and not as prone to the flakiness of the blue.
See: How I hate Plastic parts….
I still hate plastic parts, but thanks Tolusina. | VW Vortex - Volkswagen Forum
parts list:
027121133A - front flange
049919501 - dash temp sensor
035919369M - ecu temp sensor
It is listening for knocks and pings, then tells the ecu to adjust the timing either advancing it or retarding it.
If it is Bad, it can go to always retarding the engine, or advancing it to be out of range electrically.
They do go bad from time to time, and diagnosing them is well as you found out, hard to do.
