dash lights and gauge problem
I do suspect it could be the steering column contacts as i also have issues with my indicators being intermittent …
I will try and pull the relay then reconnect like [mention]Briano1234 [/mention] suggested.
‘81 Golf GTi Mk1 TSR1600 tintop
'90s Chesil Speedster on '70 VW Beetle Chassis
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
I have a how to on that
Is it my Wiper switch of my windshield pump acting up? | Volkswagen Owners Club Forum
Thanks again
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
Odometer working
LCD upgrades to instrument cluster
New earth added behind
New earth added cam cover to coil bracket
And oil temp vdo gauge added
Only issue left now is that my clock lcd (non mfa) is still randomly coming on/off/distorted. I did pad out the long connector as per the guide when working on the instrument cluster. Was hoping the new earths would help…
New LCD screen needed..?
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
for the lcd check the permanent live feed to the cluster, its the red wire and fed from fuse 3 if its ce1 type fusebox. check the pin is tight and clean in the cluster plug, look for damage on the copper pad in cluster itself. pull that fuse, check its in good nick and refit. also see if wiggling helps, could be socket is loose or dirty
Do you know what spec bulb it is as mine was missing?
Thanks for the tips on the clock. Will give that a go.
Appreciate your reply
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
after 88ish the switch and wiring was re-designed so the dimmer wheel is fed from the same fuse as the number plate lights, and the headlight switch plug is red so its easy to ID
rubjonny said
the 'strange fitting' you mention is a holder for a bulb, you push it into the socket and jobs a goodun. then the holder pushes into a hole in the back of the switch/panel/whatever you're trying to illuminate
Ya know I keep forgetting that there were 2 types of heater panels over the years, the one for the early Scirroco's had a removable bulb where as the newer styles had a fixed bulb so when it went bad you had to replace the whole panel..
Hear is a good fix for that with super bright LED's
88 Cabby Heater Control With Non-Removable Bulb ... Mod? | VW Vortex - Volkswagen Forum
Then I also forgot about the time my cluster started to act strange until I found the foil pad on the B+ was folding back on itself when I would re-connect it, and until I got it out of the car did I see what was happening.
Back in the days of a 1mb pixel camera.
A little super glue under the pad and all was good to go.
I used some to repair an edible ink cartridge of all things
My car is a 1980 so luckily bulb holder just pops out the heater fascia.
Thanks for the tips on the clock too. I put my dash back together yesterday so can’t face taking it straight back out again! I know it’s not a huge job so will see how the clock fares and then redo that pin if necessary.
Thanks again for all the advice both!
‘14 Golf GTi Mk7
‘14 Golf GTi Mk7
The car has previously had a dashboard and instruments replaced with a newer model (1980). Since I am in the process of rebuilding, I found the original dash and instruments and installed them in the car. The problem I'm having is this:
I have no light on the dial, the rest of the dash has the light working normally and
When I plug in the plug into the dial and with the ignition switch off, the turn signals stay on and repeating the clicking sound quickly, as soon as I turn on the switch everything works ok except the dial lighting.
Is it possible that I have misplaced the power wire (black) with the ground wire (brown) or the light wire (blue gray) in the plug that connects to the dial…? Or is there a short somewhere behind the starter switch…?
Any thoughts…?
the pinout is slightly different:
https://clubgti.com/forums/index.php?threads/fusebox-faq.219775/#post-1945626
rubjonny said
ok so you plugged a 1975 clock set to a 1980 wiring loom?
The other way around.
The Car is 1975, (the wiring loom is 1975) it was connected 1980 clock and now i am connecting the original one 1975.
I think there is a short circuit somewhere because the turn signals work even with the ignition switch off.
I solved the dial lighting problem, the bulbs were burnt out…
if you unplug the hazard switch, do the indicators still work? if not (and they shouldn't!) loop a wire from the white to the black/blue and indicators should only work with ignition on
I found the short circuit somewhere on the back of the fuse box and replaced a blown fuse. I also checked every single connection and wire. It was pretty messy. Now Everything works as it should.
Thanks for fast response and the link you placed on your previous post.
