K-jet pressure test results - help
If it's fully open just before you reach the floor, what happens is you put strain on the bend in the end of the cable and it opens out and the cable comes off the pedal or it rips the rubber/foam bush in the pedal if you are using or still have the Mk1 bush change it over for one fitting a Mk2 golf as they are a harder rubber and last a lot long GSF sell them for about £1, Mk1 golf bush is about £7?????
How I set mine is remove the little circlip which holds the cable in the holder on the rocker cover, get some one in the car to press the accelerator to the floor, pull the throttle body all the way open by hand then pull the plastic bit of the cable till it's tight the refit the clip to hold it in place. Job done!
