My Daily drive 1988 Gti cabriolet
Also had a go at the windscreen and rust along the seal, you could still see the black over spray underneath the seal when VW sprayed behind the dash.
Crack from stone chip last year, I was lucky and it did not get any bigger over the 11 months.
Managed to make another crack when pushing the screen out!
Screen out, managed on my own by just getting the top out then going outside the car and pulling.
Only bits of rust I could find so pleased at the results, this was the original windscreen.
Bit of cleaning
Grinding and Jenolite
No holes :-) Paint primer tonight then wait for a couple of days then top coat and find a new windscreen.
Last edit: by mark1gls
As of 3 years ago I've stopped t-cutting the paint as it's so thin.
I just want to protect the metal and stop the rust spreading then back into daily service on the road for the winter.
Lets be honest even with the age and their oddities there are still fun to drive, especially in the winter.
But I have to be honest I'm a chicken when it comes to driving a Mk1 in the winter here in Austria.
Mind you by November the 1st I have to put the Winter wheels and tyres on the Mk6 because it's law here now but I'd love to see my tyre guys face if I asked him to retread my Mk1 for the winter.
He'd die laughing!
Pictures from having new front bearings fitted and painting up the brake disc cover plates as a little rusty.
Also fitted new top mounts and tried Meyle ones and read a tip of filling the inside with silicone to make them last a bit longer so I'll see how they last.
It's back in daily service and passed it's MOT in December with no advisories. Rust sorted around front windscreen.
The brown mark is just a stain from the old seal, I'm please with the finish as I used a brush to paint the paint on. The car will be resprayed this or next year depending on money and time.
Then it rained after new screen fitted and it leaked!
The seal in the passengers corner seems not to sit flush, its as if the new screen is a little so small in that corner.
It was Christmas time.
Christmas light on the dash!
Forgot to take any pictures of the front suspension rebuild refit, 2 new front wheel bearings, new passengers side steering rack boot, hub carriers and brake disc covers all painted.
Some more pictures of a dirty car.
Then this happened last week….. Bloody POT HOLES!!!
It was hidden in a big puddle which I had to go through as I lorry was heading towards me, I was only doing about 25mph when I hit it with a big bang.
The other side of the rim is fine.
Not sure what to do yet…..
On the drive
Myvalver 89 GTi Grey mk2 16v
Had a bit of welding done to the passengers door lower hinge as the A pillar started to rot away. I had to strip the car down so they could remove the front wing.
A bit crusty around the arch, gave me a good change to clean up behind the body kit.
I was still using the car while stripping bits off, good job for cable ties..
Pleased with how solid it is as the kit has never been off before
Lower hinge and check strap fixing flapping about…
All fixed.. not the best welding I’ve seen..
Good change to take the carpets out and give the floor a good clean, found this plug underneath the sound deadening, any ideas what it’s for?
Nearly back together…
And today’s big moment….
