My Black Mk1 Gti...now a resto!!
chrisL said
Thanks, I like it on the 165's though. Is the ride not very good on them?
The ride is fine but i prefer more of a tyre…👌🏻
Well….the old golf is off the road for a while I spotted a "small" hole in the drivers side sill so decided to investigate and discovered a whole other issue lurking below the underseal It also seems the previous owner was a fantastic bodger!!! So from what started as a small hole has gone into a bit of a resto!!
So….dropped the suspension and rear axle then fuel tank etc
Behind the undersell and arch liner….started to cut some of the rot away but found more and more so decided the tub had to come out!!
Tub out !!
Noticed the rear panel was looking a bit suspicious…….Oh look the is bit has been bodged too!!
Last edit: by stev
But looks like you've grabbed the bull by the horns and are tackling it correctly
Matt
Tub Out!
tub by john stevenson, on Flickr
After a few swear words, managed to get the new tub in….IMG_0526 by john stevenson, on Flickr
The fuel filler was looking crusty (forgot to take a before pic) so chopped it out.
IMG_0527 by john stevenson, on Flickr
Welded new one in!
IMG_0532 - Copy by john stevenson, on Flickr
Buffed down the weld then some primer.
IMG_0528 by john stevenson, on Flickr
Was all quite crusty so just got on with it, sorry about the lack of before pics
IMG_0739 by john stevenson, on Flickr
IMG_0508 by john stevenson, on Flickr
Chopped it all out and got the new one in place, pretty chuffed to be honest!!
IMG_0516 by john stevenson, on Flickr
IMG_1508 by john stevenson, on Flickr
So cut the panel for the new arch, lined up and tack welded
IMG_1497 by john stevenson, on Flickr
Took my time and slowly welded it up..
IMG_1500 by john stevenson, on Flickr
IMG_1501 by john stevenson, on Flickr
Still need to grind the welds down but progress at last!!
Hairyarse said
Good work, esp. on that arch. It's brave doing a but weld there I think instead of an overlap - bloody well done!!
Thanks Hairyarse, you have me worried now as i thought butt weld there was the way to go…..
I hate finding rust and holes and corrosion and bodges. I had a similar thing with my rear panel, looked like some angry beavers had been at it!
Any other plans for the resto? Or is it a back to original plan?
Ian
borednow said
Nice work so far
Ian
Thanks Ian, The bodge jobs are driving me nuts! Keep finding more and more but will get there in the end!
Don't worry chap! It's just hard to do well and warping more likely than an overlap joint. Overlap is more prone to rust so you've done it the right way.
I took the cowards way!
Managed to get some time spent on the Golf in the last couple of weeks….so to carry on from the above
First up….grind the weld and apply some primer!
IMG_1695 by john stevenson, on Flickr
Onto the other side, same again…looking crusty!
IMG_1590 by john stevenson, on Flickr
So cut out and got the new panel in IMG_1693 by john stevenson, on Flickr
Outer arch removed to reveal inner rotten as well
IMG_1597 - Copy by john stevenson, on Flickr
Sorry forgot to take a pic of the new inner welded in…so on with the new outer
tacked in
IMG_1669 by john stevenson, on Flickr
Welded…
IMG_1671 - Copy by john stevenson, on Flickr
Valance cut out, prepped all the faces and primed..
IMG_1688 - Copy by john stevenson, on Flickr
New one welded on
IMG_1689 - Copy by john stevenson, on Flickr
Ground flat, and primed
Untitled by john stevenson, on Flickr
