My MK1 Gti resto
My MK1 Gti resto
(loads of pic)
Sent from my SM-G900F using Tapatalk
Matt
Sorry did not realise pics not in order!!!
Should be:
Red with dark etch was once all repair was done. New archs welded lead loaded and bit of filer.
Grey primer is slick sand blocked down followed by pinky primer ready for final block. One swage line out so I sort that first and go from there.
Slow progress but getting there!!
Fit the sunroof on Check that tomorrow.
My MK1 Gti resto
Posted at work…
My MK1 Gti resto
Gesendet von iPhone mit Tapatalk
- 1978 MK1 GL 2 door with 2.0 16v ABF, twin 40's, Recaros, lots of suspension mods. I'll get it back on the road one day.
- 1991 MK2 GTI 4 door. Was my daily doing over 1000 ks a week until it hit a truck. RIP. Got another one now and loving it!
- 1991 MK2 GTI 4 door for parts.
- 1998 Seat Cupra + another used as a donor for the MK1
- 1999 Passat Wagon. Needs street cred but at least it's a manual.
sports racer said
Did you prep and paint the shell but leave rust spots?
Grinded it off the rust, then rust protection over top.
Just need to remember how to upload the pictures.
Since I last posted I done the following:
Suspension built up and fitted
Gearbox rebuilt
Short Block horned and built up, new pistons, shells, crank polished etc
Head flowed, cleaned, new tappets and Cam.
Tall block built up and fitted.
New fuel and Brake lines
Brake set up built up,
Engines parts powder coated, Pulleys, cam cover rocker cover etc etc
Last edit: by Sach
So bought a set of twin 40s only when they turned up they was twin45
After doing research, Chris worked the Jets idle etc etc to run with the engine
4-2-1 manifold was fitted and exhaust.
Set the carbs up on the Exhaust gas analyser we have at work.
In-between in the evening my work colleague and myself have been flatting and polishing. Not easy when you painted 3 years ago and used anti scratch clear coat ….
Sort suspension out as springs are moving.
Start getting the wring sorted inside new ISO for head unit, speaker wires and Alarm.
Cavity wax applied
New headliner and carpet in.
Seats need attention would like to keep the standard GTI paten. So I start getting quotes on re trims etc any recommendation be much appreciated.
Finish Polishing.
Fit the windows.
Waiting for that first drive out in the sun 👍
